[postgis-users] Error while importing data
Nigel Kukard
nkukard at lbsd.net
Wed Mar 9 22:00:20 PST 2005
Hi Guys,
I'm new to postgis. I got shape files from our local government,
containing all data for South Afica.
I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
php-5.0.3 & mapserver 4.4.1
The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
pgsql.
I continued to run shp2pgsql on one of the shape files to insert it into
my database with
shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
I then tried to pipe the /tmp/postgis.sql into postgresql, but got the
following error...
BEGIN
NOTICE: CREATE TABLE will create implicit sequence "drainage_gid_seq"
for serial column "drainage.gid"
CREATE TABLE
addgeometrycolumn
public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
geometry_column fixed:0
(1 row)
ERROR: Invalid type in wbk
ERROR: current transaction is aborted, commands ignored until end of
transaction block
transaction block
transaction block
ROLLBACK
most of the shape files import fine, there are a couple of types which
give me the above error.
any help would greatly be appreciated, if need be I can attach the
actual sql file or any other info needed.
Regards
Nigel Kukard
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050310/56f38a47/attachment.pgp>
