[postgis-users] Unusual Make/Compilation Error - postgis-1.0.0-rc3
strk at refractions.net
Fri Mar 11 22:24:03 PST 2005
On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam wrote:
> I have installed PostgreSQL 8 on my Solaris 2.8 dev machine. I installed
> Proj.4 and GEOS spatial libraries and have been trying to install the
> PostGIS library with no luck so far. I downloaded and extracted
> postgis-1.0.0-rc3 under the the contrib subdirectory. When I run "make",
> I get errors not finding other Making.* files under "src". I checked for
> these Making.* files and they do exist!! However; I keep getting the
> following errors when I run "make":
You need GNU make, try 'gmake' instead of 'make' and see if it fixes
the problem.
--strk;
> anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make
> make -C lwgeom
> make[1]: Entering directory
> `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> ../Makefile.config:90: /src/Makefile.global: No such file or directory
> Makefile:98: /src/Makefile.shlib: No such file or directory
> make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
> make[1]: Leaving directory
> make: *** [liblwgeom] Error 2
> Any idea is highly appreciated. Thanks,
> Husam
> This message contains confidential information intended only for the
> use of the addressee(s) named above and may contain information that
> is legally privileged. If you are not the addressee, or the person
> responsible for delivering it to the addressee, you are hereby
> notified that reading, disseminating, distributing or copying this
> message is strictly prohibited. If you have received this message by
> mistake, please immediately notify us by replying to the message and
> delete the original message immediately thereafter.
> Thank you. FADLD Tag
> postgis-users mailing list
