[postgis-users] Error while importing data
Nigel Kukard nkukard at lbsd.net
Sun Mar 13 07:10:23 PST 2005
I see quite a number more errors (the_geom constraint violations) with
1.0.0rcX, if I paste one of these for you, could you tell me why its
happening?
Regards
Nigel
strk at refractions.net wrote:
>On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
>>Hi Guys,
>>I'm new to postgis. I got shape files from our local government,
>>containing all data for South Afica.
>>I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
>>php-5.0.3 & mapserver 4.4.1
>>The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
>>pgsql.
>>I continued to run shp2pgsql on one of the shape files to insert it into
>>my database with
>>shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
>>I then tried to pipe the /tmp/postgis.sql into postgresql,  but got the
>>following error...
>>BEGIN
>>NOTICE:  CREATE TABLE will create implicit sequence "drainage_gid_seq"
>>for serial column "drainage.gid"
>>CREATE TABLE
>>                                  addgeometrycolumn
>>public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
>>geometry_column fixed:0
>>(1 row)
>>ERROR:  Invalid type in wbk
>Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
>If you can test a CVS snapshot that would help us release RC4.
>--strk;
>>ERROR:  current transaction is aborted, commands ignored until end of
>>transaction block
>>transaction block
>>transaction block
>>ROLLBACK
>>most of the shape files import fine, there are a couple of types which
>>give me the above error.
>>any help would greatly be appreciated, if need be I can attach the
>>actual sql file or any other info needed.
>>Regards
>>Nigel Kukard
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Nigel Kukard, PhD CompSc
(Chief Executive Officer)
Linux Based Systems Design
Web: www.lbsd.net          Email: nkukard at lbsd.net
Tel: (+27) 023 349 8000     Cell: (+27) 082 333 3723
Fax: (+27) 023 349 1395  Support: 086 747 7600
Address: LIGT House, 2 Klipdrift Rd, Rawsonville
Linux Systems Design & Technology Solutions
   The best language to use is the language that was designed for
                  what you want to use it for.
Disclaimer
The contents of this message and any attachments are intended
solely for the addressee's use and may be legally privileged and/or
confidential information. This message may not be retained,
distributed, copied or used if you are not he addressee of this
message. If this message was sent to you in error, please notify
the sender immediately by reply e-mail and then destroy the message
and any copies thereof.
Opinions, conclusions and other information in this message may be
personal to the sender and is not that of Linux Based Systems Design,
LinuxRulz or any of it's subsideries, associated companies or
principals and is therefore not endorsed by Linux Based Systems
Design or LinuxRulz. Due to e-maill communication being insecure,
Linux Based Systems Design and LinuxRulz do not guarantee
confidentiality, security, accuracy or performance of the e-mail.
Any liability for viruses is excluded to the fullest extent.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050313/9331b22e/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050313/9331b22e/attachment.pgp>
