[postgis-users] Error while importing data
Nigel Kukard nkukard at lbsd.net
Mon Mar 14 04:40:10 PST 2005
sorry, forgot to mention that
i have thousands of  shapfiles for air transport... the first one I
import creates the table, the second i append ...
here is the statements created when I imported the very first shapefile..
BEGIN;
CREATE TABLE "air_transport_area" (gid serial, "gdo_gid" int8, "tag"
varchar, "feat_type" varchar, "geom_type" varchar, "mapsheet" varchar,
"row_status" varchar, "lock_date" varchar(8), "selection_" varchar,
"version_nu" numeric, "version_da" varchar(8), "version_st" varchar,
"modified_b" varchar, "retired_da" varchar(8), "original_g" numeric,
"create_dat" varchar(8), "data_sourc" varchar, "est_revisi" varchar(8),
"source_ver" int8, "source_pro" int8, "source_pro__19" int8,
"source_con" varchar, "capture_in" int8, "descriptio" varchar);
SELECT
AddGeometryColumn('','air_transport_area','the_geom','-1','MULTIPOLYGON',4);
COPY "air_transport_area"
(gid,"gdo_gid","tag","feat_type","geom_type","mapsheet","row_status","lock_date","selection_","version_nu","version_da","version_st","modified_b","retired_da","original_g","create_dat","data_sourc","est_revisi","source_ver","source_pro","source_pro__19","source_con","capture_in","descriptio","the_geom")
FROM stdin;
I have this shapefile if you need it aswell.
-Nigel
strk at refractions.net wrote:
>On Mon, Mar 14, 2005 at 12:01:14PM +0000, Nigel Kukard wrote:
>>commands i used are..  (cvs snapshot of postgis-1.0.0, RCSID: $Id:
>>shp2pgsql.c,v 1.81 2005/03/08 11:06:33 strk Exp $)
>>shp2pgsql -a -D 2327BD_AIR_TRANSPORT_AREA_ALLFEATTYPES.shp all >
>>/tmp/air_transport.sql
>>psql -U postgres all < /tmp/air_transport.sql
>Nigel, you are "appending" to an existing table (all).
>How did you create that table ?
>You probably run AddGeometryColumn() once, specifying a different
>dimension then '2', which is required by your shapefile.
>I tried both creating and appending the shapefile and it works.
>The "dimensions" constraint was not enforced in postgis 0.x, and
>this seems to give problem to more then a user...
>Do people think the check is better avoid ?
>--strk;
>>here is the error....
>>BEGIN
>>ERROR:  new row for relation "air_transport_area" violates check
>>constraint "enforce_dims_the_geom"
>>CONTEXT:  COPY air_transport_area, line 1: "12006587    12006587
>>LANDING STRIP   AREA    2327BD  A     0        \N
>>000000000000000000000001        0       \N      MDP_2   0       0
>>20020522        ..."
>>ROLLBACK
>>attached is the shapefiles i am trying to import.
>>Thanks for your help!!!
>>Regards
>>Nigel
>>>The message says you're trying to load a differently-dimensioned geometry
>>>in a table you created with a dimension constraint.
>>>The dimension constraint is added by AddGeometryColumn().
>>>If shp2pgsql did the whole thing (call AddGeometryColumn() and feed
>>>the geoms) we have a big bad bug, and having your case's shapefile
>>>would help fixing it.
>>>--strk;
>>>>Regards
>>>>Nigel
>>>>>On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
>>>>>>Hi Guys,
>>>>>>I'm new to postgis. I got shape files from our local government,
>>>>>>containing all data for South Afica.
>>>>>>I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
>>>>>>php-5.0.3 & mapserver 4.4.1
>>>>>>The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
>>>>>>pgsql.
>>>>>>I continued to run shp2pgsql on one of the shape files to insert it into
>>>>>>my database with
>>>>>>shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
>>>>>>I then tried to pipe the /tmp/postgis.sql into postgresql,  but got the
>>>>>>following error...
>>>>>>BEGIN
>>>>>>NOTICE:  CREATE TABLE will create implicit sequence "drainage_gid_seq"
>>>>>>for serial column "drainage.gid"
>>>>>>CREATE TABLE
>>>>>>                              addgeometrycolumn
>>>>>>public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
>>>>>>geometry_column fixed:0
>>>>>>(1 row)
>>>>>>ERROR:  Invalid type in wbk
>>>>>Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
>>>>>If you can test a CVS snapshot that would help us release RC4.
>>>>>--strk;
>>>>>>ERROR:  current transaction is aborted, commands ignored until end of
>>>>>>transaction block
>>>>>>transaction block
>>>>>>transaction block
>>>>>>ROLLBACK
>>>>>>most of the shape files import fine, there are a couple of types which
>>>>>>give me the above error.
>>>>>>any help would greatly be appreciated, if need be I can attach the
>>>>>>actual sql file or any other info needed.
>>>>>>Regards
>>>>>>Nigel Kukard
>>>>>>_______________________________________________
>>>>>>postgis-users mailing list
>>>>>>postgis-users at postgis.refractions.net
>>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Nigel Kukard, PhD CompSc
(Chief Executive Officer)
Linux Based Systems Design
Web: www.lbsd.net          Email: nkukard at lbsd.net
Tel: (+27) 023 349 8000     Cell: (+27) 082 333 3723
Fax: (+27) 023 349 1395  Support: 086 747 7600
Address: LIGT House, 2 Klipdrift Rd, Rawsonville
Linux Systems Design & Technology Solutions
   The best language to use is the language that was designed for
                  what you want to use it for.
Disclaimer
The contents of this message and any attachments are intended
solely for the addressee's use and may be legally privileged and/or
confidential information. This message may not be retained,
distributed, copied or used if you are not he addressee of this
message. If this message was sent to you in error, please notify
the sender immediately by reply e-mail and then destroy the message
and any copies thereof.
Opinions, conclusions and other information in this message may be
personal to the sender and is not that of Linux Based Systems Design,
LinuxRulz or any of it's subsideries, associated companies or
principals and is therefore not endorsed by Linux Based Systems
Design or LinuxRulz. Due to e-maill communication being insecure,
Linux Based Systems Design and LinuxRulz do not guarantee
confidentiality, security, accuracy or performance of the e-mail.
Any liability for viruses is excluded to the fullest extent.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/205ecae1/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/205ecae1/attachment.pgp>
