[postgis-users] Error while importing data
strk at refractions.net
Mon Mar 14 04:29:28 PST 2005
On Mon, Mar 14, 2005 at 12:01:14PM +0000, Nigel Kukard wrote:
> commands i used are.. (cvs snapshot of postgis-1.0.0, RCSID: $Id:
> shp2pgsql.c,v 1.81 2005/03/08 11:06:33 strk Exp $)
> shp2pgsql -a -D 2327BD_AIR_TRANSPORT_AREA_ALLFEATTYPES.shp all >
> /tmp/air_transport.sql
> psql -U postgres all < /tmp/air_transport.sql
Nigel, you are "appending" to an existing table (all).
How did you create that table ?
You probably run AddGeometryColumn() once, specifying a different
dimension then '2', which is required by your shapefile.
I tried both creating and appending the shapefile and it works.
The "dimensions" constraint was not enforced in postgis 0.x, and
this seems to give problem to more then a user...
Do people think the check is better avoid ?
--strk;
> here is the error....
> BEGIN
> ERROR: new row for relation "air_transport_area" violates check
> constraint "enforce_dims_the_geom"
> CONTEXT: COPY air_transport_area, line 1: "12006587 12006587
> LANDING STRIP AREA 2327BD A 0 \N
> 000000000000000000000001 0 \N MDP_2 0 0
> 20020522 ..."
> ROLLBACK
> attached is the shapefiles i am trying to import.
> Thanks for your help!!!
> Regards
> Nigel
> >The message says you're trying to load a differently-dimensioned geometry
> >in a table you created with a dimension constraint.
> >The dimension constraint is added by AddGeometryColumn().
> >If shp2pgsql did the whole thing (call AddGeometryColumn() and feed
> >the geoms) we have a big bad bug, and having your case's shapefile
> >would help fixing it.
> >--strk;
> >>Regards
> >>Nigel
> >>strk at refractions.net wrote:
> >>>On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
> >>>>Hi Guys,
> >>>>I'm new to postgis. I got shape files from our local government,
> >>>>containing all data for South Afica.
> >>>>I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
> >>>>php-5.0.3 & mapserver 4.4.1
> >>>>The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
> >>>>pgsql.
> >>>>I continued to run shp2pgsql on one of the shape files to insert it into
> >>>>my database with
> >>>>shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
> >>>>I then tried to pipe the /tmp/postgis.sql into postgresql, but got the
> >>>>following error...
> >>>>BEGIN
> >>>>NOTICE: CREATE TABLE will create implicit sequence "drainage_gid_seq"
> >>>>for serial column "drainage.gid"
> >>>>CREATE TABLE
> >>>> addgeometrycolumn
> >>>>public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
> >>>>geometry_column fixed:0
> >>>>(1 row)
> >>>>ERROR: Invalid type in wbk
> >>>Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
> >>>If you can test a CVS snapshot that would help us release RC4.
> >>>--strk;
> >>>>ERROR: current transaction is aborted, commands ignored until end of
> >>>>transaction block
> >>>>transaction block
> >>>>transaction block
> >>>>ROLLBACK
> >>>>most of the shape files import fine, there are a couple of types which
> >>>>give me the above error.
> >>>>any help would greatly be appreciated, if need be I can attach the
> >>>>actual sql file or any other info needed.
> >>>>Regards
> >>>>Nigel Kukard
> >>>>_______________________________________________
> >>>>postgis-users mailing list
> >>>>postgis-users at postgis.refractions.net
> >>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
