[postgis-users] Error while importing data
Nigel Kukard
nkukard at lbsd.net
Mon Mar 14 04:01:14 PST 2005
Hi, below error message, attached shapefiles
strk at refractions.net wrote:
>On Sun, Mar 13, 2005 at 03:10:23PM +0000, Nigel Kukard wrote:
>>Hi,
>>I see quite a number more errors (the_geom constraint violations) with
>>1.0.0rcX, if I paste one of these for you, could you tell me why its
>>happening?
commands i used are.. (cvs snapshot of postgis-1.0.0, RCSID: $Id:
shp2pgsql.c,v 1.81 2005/03/08 11:06:33 strk Exp $)
shp2pgsql -a -D 2327BD_AIR_TRANSPORT_AREA_ALLFEATTYPES.shp all >
/tmp/air_transport.sql
psql -U postgres all < /tmp/air_transport.sql
here is the error....
BEGIN
ERROR: new row for relation "air_transport_area" violates check
constraint "enforce_dims_the_geom"
CONTEXT: COPY air_transport_area, line 1: "12006587 12006587
LANDING STRIP AREA 2327BD A 0 \N
000000000000000000000001 0 \N MDP_2 0 0
20020522 ..."
ROLLBACK
attached is the shapefiles i am trying to import.
Thanks for your help!!!
Regards
Nigel
>The message says you're trying to load a differently-dimensioned geometry
>in a table you created with a dimension constraint.
>The dimension constraint is added by AddGeometryColumn().
>If shp2pgsql did the whole thing (call AddGeometryColumn() and feed
>the geoms) we have a big bad bug, and having your case's shapefile
>would help fixing it.
>--strk;
>>Regards
>>Nigel
>>>On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
>>>>Hi Guys,
>>>>I'm new to postgis. I got shape files from our local government,
>>>>containing all data for South Afica.
>>>>I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
>>>>php-5.0.3 & mapserver 4.4.1
>>>>The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
>>>>pgsql.
>>>>I continued to run shp2pgsql on one of the shape files to insert it into
>>>>my database with
>>>>shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
>>>>I then tried to pipe the /tmp/postgis.sql into postgresql, but got the
>>>>following error...
>>>>BEGIN
>>>>NOTICE: CREATE TABLE will create implicit sequence "drainage_gid_seq"
>>>>for serial column "drainage.gid"
>>>>CREATE TABLE
>>>> addgeometrycolumn
>>>>public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
>>>>geometry_column fixed:0
>>>>(1 row)
>>>>ERROR: Invalid type in wbk
>>>Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
>>>If you can test a CVS snapshot that would help us release RC4.
>>>--strk;
>>>>ERROR: current transaction is aborted, commands ignored until end of
>>>>transaction block
>>>>transaction block
>>>>transaction block
>>>>ROLLBACK
>>>>most of the shape files import fine, there are a couple of types which
>>>>give me the above error.
>>>>any help would greatly be appreciated, if need be I can attach the
>>>>actual sql file or any other info needed.
>>>>Regards
>>>>Nigel Kukard
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>postgis-users at postgis.refractions.net
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/3fce25bb/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/3fce25bb/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/3fce25bb/attachment-0001.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/3fce25bb/attachment-0002.obj>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/3fce25bb/attachment.pgp>
