[postgis-users] Error while importing data
Nigel Kukard
nkukard at lbsd.net
Mon Mar 14 05:02:31 PST 2005
strk at refractions.net wrote:
>Here you specify that the geometry column will store geometries with
>4 dimensions (XYZM).
heh, shp2pgsql specified that.. not me ... :-)
>If you want to be free to add other-dimensioned
>geometries an option you have is to drop the enforce_dims_the_geom constraint
>on your table.
cool
> Note that in that case your geometry_columns entry will
>contain a non-true specification.
would this affect mapserver btw? I'm up to try and experiment anything,
and help where I can.
>You might want to use a fake value
>there, as a notice of 'freely-dimensioned', like '-1'.
sounds like a good idea!
>Maybe we should support -1 as a dimension value to specify this, like
>we do for SRID...
I'm up to test it out!!
-Nigel
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/a6a3b742/attachment.pgp>
