[postgis-users] Error while importing data
strk at refractions.net
Mon Mar 14 05:05:58 PST 2005
On Mon, Mar 14, 2005 at 01:02:31PM +0000, Nigel Kukard wrote:
> strk at refractions.net wrote:
> >Here you specify that the geometry column will store geometries with
> >4 dimensions (XYZM).
> heh, shp2pgsql specified that.. not me ... :-)
> >If you want to be free to add other-dimensioned
> >geometries an option you have is to drop the enforce_dims_the_geom
> >constraint
> >on your table.
> cool
> >Note that in that case your geometry_columns entry will
> >contain a non-true specification.
> would this affect mapserver btw? I'm up to try and experiment anything,
> and help where I can.
> >You might want to use a fake value
> >there, as a notice of 'freely-dimensioned', like '-1'.
> sounds like a good idea!
> >Maybe we should support -1 as a dimension value to specify this, like
> >we do for SRID...
> I'm up to test it out!!
Nigel, to say the truth SRID=-1 *special* handling is not used yet,
but has been proposed. It won't be in PostGIS-1.0.0 though. The
dimension -1 will probably be implemented at the same time.
About mapserver you shouldn't have any problem as all geometries are
converted to 2d before parsing anyway, I don't think it uses
the 'dimension' field of geometry_columns at all.
--strk;
> -Nigel
> postgis-users mailing list
