[postgis-users] Error while importing data
Nigel Kukard
nkukard at lbsd.net
Mon Mar 14 05:20:53 PST 2005
is there somewhere in the code I can disable the constraint?
Regards
Nigel
strk at refractions.net wrote:
>>>Here you specify that the geometry column will store geometries with
>>>4 dimensions (XYZM).
>>heh, shp2pgsql specified that.. not me ... :-)
>>>If you want to be free to add other-dimensioned
>>>geometries an option you have is to drop the enforce_dims_the_geom
>>>constraint
>>>on your table.
>>cool
>>>Note that in that case your geometry_columns entry will
>>>contain a non-true specification.
>>would this affect mapserver btw? I'm up to try and experiment anything,
>>and help where I can.
>>>You might want to use a fake value
>>>there, as a notice of 'freely-dimensioned', like '-1'.
>>sounds like a good idea!
>>>Maybe we should support -1 as a dimension value to specify this, like
>>>we do for SRID...
>>I'm up to test it out!!
>Nigel, to say the truth SRID=-1 *special* handling is not used yet,
>but has been proposed. It won't be in PostGIS-1.0.0 though. The
>dimension -1 will probably be implemented at the same time.
>About mapserver you shouldn't have any problem as all geometries are
>converted to 2d before parsing anyway, I don't think it uses
>the 'dimension' field of geometry_columns at all.
>--strk;
>>-Nigel
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Nigel Kukard, PhD CompSc
(Chief Executive Officer)
Linux Based Systems Design
Web: www.lbsd.net Email: nkukard at lbsd.net
Tel: (+27) 023 349 8000 Cell: (+27) 082 333 3723
Fax: (+27) 023 349 1395 Support: 086 747 7600
Address: LIGT House, 2 Klipdrift Rd, Rawsonville
Linux Systems Design & Technology Solutions
The best language to use is the language that was designed for
what you want to use it for.
Disclaimer
The contents of this message and any attachments are intended
solely for the addressee's use and may be legally privileged and/or
confidential information. This message may not be retained,
distributed, copied or used if you are not he addressee of this
message. If this message was sent to you in error, please notify
the sender immediately by reply e-mail and then destroy the message
and any copies thereof.
Opinions, conclusions and other information in this message may be
personal to the sender and is not that of Linux Based Systems Design,
LinuxRulz or any of it's subsideries, associated companies or
principals and is therefore not endorsed by Linux Based Systems
Design or LinuxRulz. Due to e-maill communication being insecure,
Linux Based Systems Design and LinuxRulz do not guarantee
confidentiality, security, accuracy or performance of the e-mail.
Any liability for viruses is excluded to the fullest extent.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/b6188d39/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/b6188d39/attachment.pgp>
