[postgis-users]CONNECTION to database thru Mapserver
strk at refractions.net
Mon Mar 14 08:23:59 PST 2005
On Mon, Mar 14, 2005 at 08:20:55AM -0800, w m wrote:
> Hi,
> I created a Mapserver layer definition in order to establish a connection to my database. I would like to display the data from the database on my map.
> The table spots has just points in the "the_geom" column. All I want to do is to display those points on the map. When I write my layer definition, it gives me no errors but it also doesnt display those points on the map.
> Here is my layer definition:
> LAYER
> CONNECTIONTYPE postgis
> NAME "Spots" # my table name
> CONNECTION "user=test password=test dbname=MyDataBase host=http://localhost"
host=localhost
also, try adding a SIZE to your class
--strk;
> DATA "the_geom FROM Spots" # the_geom column from table Spots
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> Thank You
> Wokar
> Do you Yahoo!?
> Yahoo! Small Business - Try our new resources site!
> postgis-users mailing list
