[postgis-users]CONNECTION to database thru Mapserver
Doug_Newcomb at fws.gov
Mon Mar 14 08:58:16 PST 2005
>From what I recall in the mapserver docs, you need to have a real IP
address designated for the postgresql server ( set in postgresql.conf) and
use that ip address in the map file,
in postgresql.conf:
listen addresses='192.168.0.100'
you also have to adjust pg_hba.conf to allow connections from
192.168.0.100
in mapfile
CONNECTION "user=test password=test dbname=MyDataBase host=192.168.0.100"
I'm not sure if the localhost 127.0.0.1 would do.
Make sure to adjust your firewall to prevent outside machines from
connecting to port 5432 ( postgresql). This is not blocked by default on
many linux distributions.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
I left my signature file in /dev/null
| | strk at refractions.net |
| | Sent by: |
| | postgis-users-bounces at postgis.refr|
| | actions.net |
| | 03/14/2005 11:23 AM |
| | Please respond to PostGIS Users |
| | Discussion |
| To: postgis <postgis-users at postgis.refractions.net> |
| cc: |
| Subject: Re: [postgis-users]CONNECTION to database thru Mapserver |
On Mon, Mar 14, 2005 at 08:20:55AM -0800, w m wrote:
> Hi,
> I created a Mapserver layer definition in order to establish a connection
to my database. I would like to display the data from the database on my
map.
> The table spots has just points in the "the_geom" column. All I want to
do is to display those points on the map. When I write my layer
definition, it gives me no errors but it also doesnt display those points
on the map.
> Here is my layer definition:
> LAYER
> CONNECTIONTYPE postgis
> NAME "Spots" # my table name
host=http://localhost"
host=localhost
also, try adding a SIZE to your class
--strk;
> DATA "the_geom FROM Spots" # the_geom column from table Spots
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> Thank You
> Wokar
> Do you Yahoo!?
> Yahoo! Small Business - Try our new resources site!
> postgis-users mailing list
