[postgis-users]CONNECTION to database thru Mapserver
w m
wokar1 at yahoo.com
Mon Mar 14 09:02:56 PST 2005
Thank You for your response.
i made the changes that you suggested but i still have no luck in displaying the points on the map. I'm not sure if a connection is being established to the database or not...how can i know that?? and instead of local host i also tried to insert the ip address of my server but it still didnt work nor did i get any errors.
any help would be appreciated greately
thank you
wokar
LAYER
CONNECTIONTYPE postgis
NAME "Spots" # my table name
CONNECTION "user=test password=test dbname=MyDataBase host=localhost"
DATA "the_geom FROM Spots" # the_geom column from table Spots
STATUS ON
TYPE POINT
CLASS
COLOR 0 0 0
OUTLINECOLOR 0 0 0
SIZE 2
END
END
strk at refractions.net wrote:
On Mon, Mar 14, 2005 at 08:20:55AM -0800, w m wrote:
> Hi,
> I created a Mapserver layer definition in order to establish a connection to my database. I would like to display the data from the database on my map.
> The table spots has just points in the "the_geom" column. All I want to do is to display those points on the map. When I write my layer definition, it gives me no errors but it also doesnt display those points on the map.
> Here is my layer definition:
> LAYER
> CONNECTION "user=test password=test dbname=MyDataBase host=http://localhost"
host=localhost
also, try adding a SIZE to your class
--strk;
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> Thank You
> Wokar
> Do you Yahoo!?
> Yahoo! Small Business - Try our new resources site!
> postgis-users mailing list
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/4946f5e6/attachment.html>
