[postgis-users]CONNECTION to database thru Mapserver
strk at refractions.net
Mon Mar 14 09:14:12 PST 2005
Are you sure your points fall in your map's EXTENT ?
Do you need to reproject them ?
--strk;
On Mon, Mar 14, 2005 at 09:02:56AM -0800, w m wrote:
> Thank You for your response.
> i made the changes that you suggested but i still have no luck in displaying the points on the map. I'm not sure if a connection is being established to the database or not...how can i know that?? and instead of local host i also tried to insert the ip address of my server but it still didnt work nor did i get any errors.
> any help would be appreciated greately
> thank you
> wokar
> LAYER
> CONNECTIONTYPE postgis
> NAME "Spots" # my table name
> CONNECTION "user=test password=test dbname=MyDataBase host=localhost"
> DATA "the_geom FROM Spots" # the_geom column from table Spots
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> SIZE 2
> END
> END
> strk at refractions.net wrote:
> On Mon, Mar 14, 2005 at 08:20:55AM -0800, w m wrote:
> > Hi,
> > I created a Mapserver layer definition in order to establish a connection to my database. I would like to display the data from the database on my map.
> > The table spots has just points in the "the_geom" column. All I want to do is to display those points on the map. When I write my layer definition, it gives me no errors but it also doesnt display those points on the map.
> > Here is my layer definition:
> > LAYER
> > CONNECTION "user=test password=test dbname=MyDataBase host=http://localhost"
> host=localhost
> also, try adding a SIZE to your class
> --strk;
> > STATUS ON
> > TYPE POINT
> > CLASS
> > COLOR 0 0 0
> > OUTLINECOLOR 0 0 0
> > END
> > END
> > Thank You
> > Wokar
> > Do you Yahoo!?
> > Yahoo! Small Business - Try our new resources site!
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
