[postgis-users]CONNECTION to database thru Mapserver
pram at pramcentral.com
Mon Mar 14 13:50:14 PST 2005
If the webserver and the postgreSQL server are on the same box, try specifying the with localhost or 127.0.0.1 in ur mapfile
ie. the mapfile should be something like:
LAYER
NAME major_roads
STATUS DEFAULT
CONNECTIONTYPE postgis
CONNECTION "dbname=tiger host=localhost user=username password=password"
-Prashanth
P.S I don't think this is a postgis issue anymore. I think it's a mapserver/mapfile issue. Please consider moving it to the mapserver mailing list.
<a href="HTMLX.com">HTMLX.com</A>
Mapserver Hosting, Mapscript Hosting, PHP Hosting
PostgreSQL w/PostGIS extension enabled Hosting
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users]CONNECTION to database thru Mapserver
Date: Mon, 14 Mar 2005 13:32:47 -0800 (PST)
> the configuration files are fine and they allow the
> connections....but still to no avail after changing STATUS to
> DEFAULT i still get the same errors. if i change STATUS to ON i
> dont see the points on the map but tehre are no errors.....
> Doug_Newcomb at fws.gov wrote:
> Wokar,
> Check your postgresql.conf file to see if you are allowing tcp/ip
> connections and your pg_hba.conf file to see if you are allowing
> connections from 132.205.108.60
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of Interior.
> I left my signature file in /dev/null
