[postgis-users]CONNECTION to database thru Mapserver
Ethan Alpert ealpert at digitalglobe.com
Mon Mar 14 15:19:05 PST 2005
Did you try what the error message says to try?
ie:
the_geom from spots using SRID=<your SRID>
or
the_geom from (select * from spots) as foo using unique oid using srid =
<your SRID>
The latter requires you to set up an oid index:
create INDEX spots_oid on spots (oid);
-e
	-----Original Message-----
	From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of w m
	Sent: Monday, March 14, 2005 3:43 PM
	To: PostGIS Users Discussion
	Subject: RE: [postgis-users]CONNECTION to database thru
Mapserver
	Thank You Doug and Ethan:)
	The connection is fine now. there were some things that did
needed to be changed in the configuration files.
	Now I get the error below. I did some  search and I think that I
would have to upgrade postgis, is it true?
	msDrawMap(): Image handling error. Failed to draw layer named
'Hotspots'.
	prep_DB(): Query error. Error executing POSTGIS DECLARE (the
actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d()),'NDR'),OID::text from WHERE &&
setSRID('BOX3D(-73.992437 45.0227318333333,-73.174263
45.9772681666667)'::BOX3D, find_srid('','','') )'
	Postgresql reports the error as 'ERROR: syntax error at or near
"WHERE" at character 104 '
	More Help:
	Error with POSTGIS data variable. You specified '<check your
.map file>'.
	Standard ways of specifiying are :
	(1) 'geometry_column from geometry_table'
	(2) 'geometry_column from (<sub query>) as foo using unique
<column name> using SRID=<srid#>'
	Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
	For more help, please see
http://postgis.refractions.net/documentation.php
	Mappostgis.c - version of Jan 23/2004.
	msPOSTGISLayerParseData(): Query error. Error parsing POSTGIS
data variable. Must contain 'geometry_column from table_name' or 'geom
from (subselect) as foo' (couldnt find ' from '). More help:
	Error with POSTGIS data variable. You specified 'the_geom FROM
Hotspots'.
SRID=#' clauses in.
	Ethan Alpert <ealpert at digitalglobe.com> wrote:
		Maybe there's a case sensitivity problem. Try using all
lower case for your db name.
		-e
			Sent: Monday, March 14, 2005 2:33 PM
			Subject: Re: [postgis-users]CONNECTION to
			the configuration files are fine and they allow
the connections....but  still to no avail after changing STATUS to
DEFAULT i still get the same errors.  if i change STATUS to ON i dont
see the points on the map but tehre are no errors.....
			Doug_Newcomb at fws.gov wrote:
				Wokar,
				Check your postgresql.conf file to see
if you are allowing tcp/ip
				connections and your pg_hba.conf file to
see if you are allowing
				connections from 132.205.108.60
				Doug
				Doug Newcomb
				USFWS
				Raleigh, NC
				919-856-4520 ext. 14
doug_newcomb at fws.gov
				The opinions I express are my own and
are not representative of the
				official policy of the U.S.Fish and
Wildlife Service or Dept. of Interior.
				I left my signature file in /dev/null
				| | w m |
				| | Sent by: |
				| | postgis-users-bounces at postgis.refr|
				| | actions.net |
				| | 03/14/2005 02:12 PM |
				| | Please respond to PostGIS Users |
				| | Discussion |
				| To: PostGIS Users Discussion |
				| cc: |
to database thru Mapserver |
				Thanks for your reply. when I changed my
STAUS to Default it gives me the
				following error:
Failed to draw layer named 'Hotspots'.
				msPOSTGISLayerOpen(): Query error.
couldnt make connection to DB with
				connect string 'user=project
password=test dbname=Montreal
				host=132.205.108.60'.
				Error reported was 'could not connect to
server: Connection refused Is the
				server running on host "132.205.108.60"
and accepting TCP/IP connections on
				port 5432? '.
				This error occured whe n trying to make
a connection to the specified
				postgresql server.
				Most commonly this is caused by
				(1) incorrect connection string
				(2) you didnt specify a 'user=...' in
your connection string
				(3) the postmaster (postgresql server)
isnt running
				(4) you are not allowing TCP/IP
connection to the postmaster
				(5) your postmaster is not running on
the correct port - if its not on 5432
				you must specify a 'port=...'
				(6) the security on your system does not
allow the webserver (usually user
				'nobody') to make socket connections to
the post master
				(7) you forgot to specify a 'host=...'
if the postmaster is on a different
				machine
				(8) you made a typo
				My server is running, what I am not sure
is (4) and (5). Can you please
				explain me how can I check the above.
Also the user name and password is
				the user name and password for the
database right?
				pram at pramcentral.com wrote:
				----- Original Message -----
				To: "P ostGIS Users Discussion"
				Date: Mon, 14 Mar 2005 09:02:56 -0800
(PST)
				> Thank You for your response.
				> i made the changes that you suggested
but i still have no luck in
				> displaying the points on the map. I'm
not sure if a connection is
				> being established to the database or
not...how can i know that??
				> and instead of local host i also tried
to insert the ip address of
				> my server but it still didnt work nor
did i get any errors.
				> any help would be appreciated greately
				> thank you
				> wokar
				> LAYER
				> CONNECTIONTYPE postgis
				> NAME "Spots" # my table name
				> CONNECTION "user=test password=test
dbname=MyDataBase host=localhost"
				> DATA "the_geom FROM Spots" # the_geom
column from table Spots
				> STATUS ON
				> TYPE POINT
				> CLASS
				> COLOR 0 0 0
				> OUTLINECOLOR 0 0 0
				> SIZE 2
				> END< BR>> ; END
				Have you tried with STATUS DEFAULT
instead of STATUS ON
				-Prashanth
				HTMLX.com
				Mapserver, Mapscript, PHP Hosting
				postgis-users mailing list
				postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________________________________________________
				Do You Yahoo!?
				Tired of spam? Yahoo! Mail has the best
spam protection around
				http://mail.yahoo.com
			Do you Yahoo!?
			Yahoo! Small Business - Try our new resources
site!
<http://us.rd.yahoo.com/evt=31637/*http://smallbusiness.yahoo.com/resour
ces/>
	Do you Yahoo!?
	Yahoo! Small Business - Try our new resources site!
ces/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/43275d9d/attachment.html>
