[postgis-users] release status
strk at refractions.net
Tue Mar 15 01:16:01 PST 2005
This is the updated CHANGES since RC3:
- early return from force_collection
- segfault fix in geom_accum()
- consistency check fix in SnapToGrid()
- jdbc2: code cleanups, Makefile improvements
- FLEX & YACC variables set *after* pgsql Makefile.global
is included and only if the pgsql *stripped* version
evaulates to the empty string
- added already generated parser in release
- build scripts refinements
- MultiLine handling BUG fix in loader and dumper
- improved version handling, central Version.config
- added distance_sphere function
- subselects support in selectivity estimator
- bug fixes for 64bit architectures
- bugfix in loaded, skipping all but first hole of polygons.
We have only two *unconfirmed* bug reports:
http://postgis.refractions.net/bugs/
Once those entries are closed we'd release RC4, which will hopefully
become final release with no changes.
Please, run your tests and report any other possible issue.
Thanks.
--strk;
