AW: [postgis-users] cannot enter password to load shp
Klingseisen Bernhard Bernhard.Klingseisen at arcs.ac.at
Tue Mar 15 02:16:50 PST 2005
Hi Nicolas,
thanks for your advice! Now I can finally load geodata into my DB.
Bernie
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von RIBOT, Nicolas
Gesendet: Montag, 14. März 2005 16:08
An: 'PostGIS Users Discussion'
Betreff: RE: [postgis-users] cannot enter password to load shp
> I'm trying to load shapefiles into postgis in the DOS command > window and
with the interface "s2pface". When running shp2pgsql I am requested to enter
a password on the DOS prompt, > but I cannot write anything on the command
line. I'm using XP > Pro and am not sure if it has to do with XP or anything
else.
> Did anybody have the same experience. I would appreciate any > useful
tips, even if my question may not be directly related > to postgis.
Hello,
S2pface does not include a box to enter the postgresql password.
2 options then: either set your postgresql access to "trust" (in the
pg_hba.conf file) and you wont need to enter a password,
or (better) use shp2pgsql in command line. It is pretty straightforward.
Typing shp2pgsql in a command windows will show you the command line help.
(sp2face is just a GUI to shp2pgsql)
Nicolas
