[postgis-users] Has anyone considered interpolation of sparse point networks?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 17 06:29:18 PST 2005
Gerry,
I have done something similar in the past where I have used the points
to create a triangularized 3D surface, using the scalar at the vertices
as the Z value, then you can quickly and easily contour the
triangularized surface by intersecting the triangles with Z-planes and
collect the intersection lines into polylines.
If you search the web for triangular surface algorithm You should find
some code that allow you to insert you point into a plan and have it
develop a surface. Once this is down slicing the triangles is trivial,
an then you need to collect the intersections fragments into a polyline(s).
Does PostGIS have any tools to assist in these steps?
-Steve W.
Gerry Creager N5JXS wrote:
> I'm getting a dataset on a daily basis that we're putting into PostGIS.
> It's a triangulated irregular network (although others will be
> quadrilateral irregular networks, or irregular polygons) with a scalar
> at the vertices.
> I will be saving these in PostGIS, and as part of the visualization
> process (I'll also post appropriate questions toward the Mapserver list)
> we're going to need to interpolate to create a processed, synthetic
> dataset of contours.
> This seems like it should be straightforward, but I'm having a little
> trouble organizing a strategy and getting started.
> Has anyone else looked at this sort of problem and done something similar?
> Thanks,
> Gerry
