[postgis-users] Has anyone considered interpolation of sparse point networks?
Gerry Creager N5JXS gerry.creager at tamu.edu
Thu Mar 17 07:14:43 PST 2005
Steve,
Thanks.  That's along the lines I was thinking, but it really helps
crystalize my thinking.
I'll report back.
Gerry
Stephen Woodbridge wrote:
> Gerry,
> I have done something similar in the past where I have used the points
> to create a triangularized 3D surface, using the scalar at the vertices
> as the Z value, then you can quickly and easily contour the
> triangularized surface by intersecting the triangles with Z-planes and
> collect the intersection lines into polylines.
> If you search the web for triangular surface algorithm You should find
> some code that allow you to insert you point into a plan and have it
> develop a surface. Once this is down slicing the triangles is trivial,
> an then you need to collect the intersections fragments into a polyline(s).
> Does PostGIS have any tools to assist in these steps?
> -Steve W.
> Gerry Creager N5JXS wrote:
>> I'm getting a dataset on a daily basis that we're putting into
>> PostGIS.  It's a triangulated irregular network (although others will
>> be quadrilateral irregular networks, or irregular polygons) with a
>> scalar at the vertices.
>> I will be saving these in PostGIS, and as part of the visualization
>> process (I'll also post appropriate questions toward the Mapserver
>> list) we're going to need to interpolate to create a processed,
>> synthetic dataset of contours.
>> This seems like it should be straightforward, but I'm having a little
>> trouble organizing a strategy and getting started.
>> Has anyone else looked at this sort of problem and done something
>> similar?
>> Thanks,
>> Gerry
> postgis-users mailing list
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
