[postgis-users] Problem getting started
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Mar 18 09:06:01 PST 2005
Hi all,
I created my database, used shp2pgsql to load some polygons, created the
indexes, etc. But when I try to render the map I get the error below.
Something is clearly broken as the table name is missing before the
WHERE and some term is missing between the "WHERE &&" so I'm open to
suggestions at this point.
-Steve W.
PostgreSQL 7.4.7 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
3.4.2 [FreeBSD] 20040728
PostGIS 1.0RC3
shp2img -v
MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
THE PROBLEM:
woodbri at linus:/u/data$ shp2img -m maps/zcta.map -o test.png
shp2img in free(): warning: chunk is already free
msDrawMap(): Image handling error. Failed to draw layer named 'zcta'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d()),'NDR'),gid::text from WHERE &&
setSRID('BOX3D(-180 -14.825,-51.75 113.425)'::BOX3D, -1 )'
Postgresql reports the error as 'ERROR: syntax error at or near "WHERE"
at character 104
THE MAPFILE LAYER:
LAYER
NAME "zcta"
STATUS DEFAULT
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "user=pgsql dbname=census"
DATA "the_geom FROM zcta using SRID=-1 using unique gid"
LABELMAXSCALE 150000
LABELITEM "name"
CLASS
COLOR 238 238 238
OUTLINECOLOR 170 170 153
LABEL
TYPE TRUETYPE
FONT "arial-bold"
SIZE 12
POSITION CC
BUFFER 3
COLOR 170 204 153
ANTIALIAS TRUE
END
END
END
