[postgis-users] Problem getting started
André Cruvinel Resende andrecruvinel at yahoo.com.br
Fri Mar 18 09:28:59 PST 2005
Hi...
Try change de 'FROM' to 'from' in you DATA object.
There is a wiki about this at:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?QueryError
[]´s
Andre
Stephen Woodbridge wrote:
> Hi all,
> I created my database, used shp2pgsql to load some polygons, created
> the indexes, etc. But when I try to render the map I get the error
> below. Something is clearly broken as the table name is missing before
> the WHERE and some term is missing between the "WHERE   &&" so I'm
> open to suggestions at this point.
> -Steve W.
> PostgreSQL 7.4.7 on i386-portbld-freebsd5.3, compiled by GCC cc (GCC)
> 3.4.2 [FreeBSD] 20040728
> PostGIS 1.0RC3
> shp2img -v
> MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE DEBUG=MSDEBUG
> THE PROBLEM:
> woodbri at linus:/u/data$ shp2img -m maps/zcta.map -o test.png
> shp2img in free(): warning: chunk is already free
> msDrawMap(): Image handling error. Failed to draw layer named 'zcta'.
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d()),'NDR'),gid::text from  WHERE  &&
> setSRID('BOX3D(-180 -14.825,-51.75 113.425)'::BOX3D, -1 )'
> Postgresql reports the error as 'ERROR:  syntax error at or near
> "WHERE" at character 104
> THE MAPFILE LAYER:
>   LAYER
>     NAME "zcta"
>     STATUS DEFAULT
>     TYPE POLYGON
>     CONNECTIONTYPE postgis
>     CONNECTION "user=pgsql dbname=census"
>     DATA "the_geom FROM zcta using SRID=-1 using unique gid"
>     LABELMAXSCALE 150000
>     LABELITEM "name"
>     CLASS
>       COLOR 238 238 238
>       OUTLINECOLOR 170 170 153
>       LABEL
>         TYPE TRUETYPE
>         FONT "arial-bold"
>         SIZE 12
>         POSITION CC
>         BUFFER 3
>         COLOR 170 204 153
>         ANTIALIAS TRUE
>       END
>     END
>   END
> postgis-users mailing list
