[postgis-users] WKB Geometry Column
Sean M. Montague
smontague at ATSDenver.com
Fri Mar 18 09:21:03 PST 2005
Does this sound reasonable? Given that pulling from the database is
faster as WKB, would it be worth the effort to develop a client side app
that parses the binary data, and appends the node of an empty SVG
document. I know this is possible with JS, appending nodes of svg
documents once they're client side. What are the possible pros and cons
of doing this? Thanks.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Thursday, March 17, 2005 3:17 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] WKB Geometry Column
Stephen Woodbridge wrote:
> I have follow up questions.
> What applications on the client side use the WKB format now?
Mapserver, Geotools (Geoserver / uDig), for a few.
> Where is the WKB format documented?
In the OpenGIS SGSQL standard. Probably we should copy that description
into our own documentation.
> As I think it would make sense to build a PHP and Perl Class the can
> parse the WKB into data structures if they don't already exist. Do
these
> already exist?
Not sure. I have done half-assed perl WKB handlers in the past, but they
are long gone into the bit bucket...
Paul
> -Steve
> Paul Ramsey wrote:
>> Sean,
>> You are confusing storage format with inout/output format. No matter
>> how you get data *into* postgis, it will be stored the same way,
using
>> the same internal structure. You have three choices for getting data
>> into and out of postgis:
>> - Use the "canonical format". This is a string representation of the
>> internal format. It might change, if we want to change the internal
>> format. It currently looks a lot like WKB, but it is not. You can see
>> the canonical format by going "select geom_column from geom_table".
>> - Use WKT. This is a human readable form of the geometry, using
>> numbers and brackets and whatnot. You can see the WKT format by
going
>> "select astext(geom_column) from geom_table".
>> - Use WKB. This is a computer readable form of hte geometry, a
>> byte-stream. You can see the canonical format by going "select
>> asbinary(geom_column) from geom_table".
>> The only thing that is "faster" about WKB is your handling of it on
>> the client side. It is much faster for client software to parse the
>> byte-stream than it for it to parse WKT. PostGIS itself will not have
>> noticably different performance if you use WKB or WKT on output.
>> Paul
