[postgis-users] PostGIS 1.0.0 R4
alexbodn at 012.net.il
Sun Mar 20 00:45:37 PST 2005
hi friends,
> USE_PROJ
> > = 1 (installed under /usr/local/bin) and USE_GEOS = 1,
/usr/local/bin looks strange for me?!
regards,
alex
----- Original Message -----
Date: Sunday, March 20, 2005 9:44 am
Subject: Re: [postgis-users] PostGIS 1.0.0 R4
> On Sat, Mar 19, 2005 at 06:35:37PM +0100, Petra Malcher wrote:
> > I installed PostGIS 1.0.0 R4 with the Makefile.config settings
> USE_PROJ
> > but failed to use the transform() function propably.
> > SELECT AsText (TRANSFORM( ( 'SRID=104102;POINT(47.5,11.2)' ,
> 31291) );
> > ERROR: PostGis transform() called, but support not compiled
> in ...
> > Does anybody know the reason?
> If you first compiled w/out PROJ support, then added it you have
> to make sure to run make clean before make again.
> If make clean; make install gives you the same problem make
> sure you're using the just-installed line.
> Also check gcc invocation (output of make) to see if -DUSE_PROJ is
> present.
> --strk;
> > Petra
> > ____________________________________________
> > Mag. Petra Malcher
> > Institute for Meteorology and Geophysics
> > University of Innsbruck
> > Innrain 52
> > A-6020 Innsbruck
> > AUSTRIA
> > Tel: ++43 512 507 5454
> > Fax: ++43 512 507 2924
> > E-mail: petra.malcher at uibk.ac.at
> > WWW: http://dude.uibk.ac.at
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
