[postgis-users] PostGIS 1.0.0 R4
strk at refractions.net strk at refractions.net
Sun Mar 20 07:03:35 PST 2005
On Sun, Mar 20, 2005 at 10:45:37AM +0200, alexbodn at 012.net.il wrote:
> hi friends,
> > USE_PROJ
> > > = 1 (installed under /usr/local/bin) and USE_GEOS = 1,
> /usr/local/bin looks strange for me?!
I agree.. default is /usr/local, should probably remain such.
--strk;
> regards,
> alex
> ----- Original Message -----
> From: strk at refractions.net
> Date: Sunday, March 20, 2005 9:44 am
> Subject: Re: [postgis-users] PostGIS 1.0.0 R4
> > On Sat, Mar 19, 2005 at 06:35:37PM +0100, Petra Malcher wrote:
> > > I installed PostGIS 1.0.0 R4 with the Makefile.config settings
> > USE_PROJ
> > > but failed to use the transform() function propably.
> > >    SELECT AsText (TRANSFORM( ( 'SRID=104102;POINT(47.5,11.2)' ,
> > 31291) );
> > >    ERROR: PostGis transform() called, but support not compiled
> > in ...
> > > Does anybody know the reason?
> > If you first compiled w/out PROJ support, then added it you have
> > to make sure to run make clean before make again.
> > If make clean; make install gives you the same problem make
> > sure you're using the just-installed line.
> > Also check gcc invocation (output of make) to see if -DUSE_PROJ is
> > present.
> > --strk;
> > > Petra
> > > ____________________________________________
> > >  Mag. Petra Malcher
> > >  Institute for Meteorology and Geophysics
> > >  University of Innsbruck
> > >  Innrain 52
> > >  A-6020 Innsbruck
> > >  AUSTRIA
> > >  Tel: ++43 512 507 5454
> > >  Fax: ++43 512 507 2924
> > >  E-mail: petra.malcher at uibk.ac.at
> > >  WWW: http://dude.uibk.ac.at
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
