[postgis-users] Installation Error - postgis-1.0.0-rc4
Tomeh, Husam htomeh at firstam.com
Mon Mar 21 12:30:50 PST 2005
That's what the SA informed me. Here's the output from : make --version
 anadev10 /p01/download :) make --version
GNU Make 3.80
Copyright (C) 2002  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
 Husam
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Monday, March 21, 2005 12:18 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Installation Error - postgis-1.0.0-rc4
> anadev10#pkginfo -l SMCmake
Are you sure 'SMCmake' is what you are running ?
Try
	# make --version
--strk;
On Mon, Mar 21, 2005 at 11:51:58AM -0800, Tomeh, Husam wrote:
> When SA attempt to install it, it complain about "-C" of make.
> anadev10#pwd
> /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4
> anadev10#make install
> make -C lwgeom
> Usage : make [ -f makefile ][ -K statefile ]... [ -d ][ -dd ][ -D ][
> -DD ]
>              [ -e ][ -i ][ -k ][ -n ][ -p ][ -P ][ -q ][ -r ][ -s ][
> -S ][ -t ]
>              [ -u ][ -w ][ -V ][ target... ][ macro=value... ][ "macro
> +=value"... ]
> make: Fatal error: Unknown option `-C'
> *** Error code 1
> make: Fatal error: Command failed for target `liblwgeom'
> ___________________________________________
> This is the make we have on that server:
> > > > > >    PKGINST:  SMCmake
> > > > > >   CATEGORY:  application
> > > > > >       ARCH:  sparc
> > > > > >    VERSION:  3.80
> > > > > >    BASEDIR:  /usr/local
> > > > > >     VENDOR:  Free Software Foundation
> > > > > >     PSTAMP:  Steve Christensen
> > > > > >   INSTDATE:  Mar 15 2005 13:51
> > > > > >      EMAIL:  steve at smc.vnet.net
> > > > > >     STATUS:  completely installed
> > > > > >      FILES:       50 installed pathnames
> > > > > >                    5 shared pathnames
> > > > > >                    7 directories
> > > > > >                    1 executables
> > > > > >                 4661 blocks used (approx)
>   Husam
> Tomeh, Husam
> Sent: Monday, March 21, 2005 11:27 AM
> Subject: RE: [postgis-users] Compilation Error - postgis-1.0.0-rc4
> That worked. Thanks for your help. Compiled perfectly.
> Sent: Monday, March 21, 2005 11:21 AM
> Subject: Re: [postgis-users] Compilation Error - postgis-1.0.0-rc4
> On Mon, Mar 21, 2005 at 10:22:03AM -0800, Tomeh, Husam wrote:
> > Thanks. I created the patch file and placed it on postgis. I ran
> > "patch < Makefile.patch" and got this error:
> >   Looks like a unified context diff.
> >   I can't seem to find a patch in there anywhere.
> > Was this the right procedure to install your patch?
> > Thanks,
> Do it manually.. it basically quotes grep argument:
> 	grep -v ^#
> becomes:
> 	grep -v '^#'
> --strk;
> >   Husam
> > Sent: Monday, March 21, 2005 9:30 AM
> > On Mon, Mar 21, 2005 at 09:23:37AM -0800, Tomeh, Husam wrote:
> > > Since I'm still having problems with rc3, I downloaded rc4. I get
> > > the following error when running make:
> > > cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
> > > 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.0:g;s:@POSTGIS_VERSIO
> > > N@
> > > :1
> > > .0
> > > USE_GEOS=1 USE_PROJ=1
> > > USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.2.1:g;s/@POSTGIS_BUILD
> > > _D
> > > AT
> > > E@
> > > /2005-03-21 17:13:03/g' | grep -v ^# > lwpostgis.sql
> > Apply this patch and see what happen:
> > Index: lwgeom/Makefile
> > RCS file: /home/cvs/postgis/postgis/lwgeom/Makefile,v
> > retrieving revision 1.72
> > diff -U2 -r1.72 Makefile
> > --- lwgeom/Makefile     18 Mar 2005 12:43:23 -0000      1.72
> > +++ lwgeom/Makefile     21 Mar 2005 17:46:41 -0000
> > @@ -139,5 +139,5 @@
> >  lwpostgis.sql: lwpostgis.sql.in
> > -       cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< |
sed
> -e
> > 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POST
> > GI
> > S_
> > VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTG
> > IS _B UILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v ^# > $@
> > +       cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< |
> > + sed -e
> > + 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(PO
> > + ST
> > + GI
> > + S_VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@P
> > + OS TG IS_BUILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> >  install: all installdirs install-lwgeom-lib install-lwgeom-scripts
> > --strk;
> > > cp lwpostgis.sql ..
> > > Usage: grep -hblcnsviw pattern file . . .
> > > cp: cannot access lwpostgis.sql
> > > make[1]: *** [../lwpostgis.sql] Error 2
> > > make[1]: Leaving directory
> > > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4/lwgeom'
> > > make: *** [liblwgeom] Error 2
> > > Any thoughts?
> > > Thanks,
> > >   Husam
> > > Of strk at refractions.net
> > > Sent: Friday, March 18, 2005 9:18 AM
> > > Subject: Re: [postgis-users] Unusual Make/Compilation Error -
> > > postgis-1.0.0-rc3
> > > On Fri, Mar 18, 2005 at 08:24:05AM -0800, Tomeh, Husam wrote:
> > > > Although I did run configure before; however, running it again
> > > > did
> > > help.
> > > > I ran into another error (see below). Is setting up postgis on a
> > > > Linux
> > > > more straightforward than Solaris? Or it does not matter really?
> > > Try current CVS, it contains the parser files already so you don't
> > > have to generate them again.
> > > --strk;
> > > > Thanks..
> > > > anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make
> > > > make -C lwgeom
> > > > make[1]: Entering directory
> > > > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> > > > sh ../geos_version.sh /usr/local > postgis_geos_version.h bison
> > > > -y
> > > > -vd
> > > > -p lwg_parse_yy wktparse.y
> > > > make[1]: *** [wktparse.tab.c] Broken Pipe
> > > >   Husam
> > > > Sent: Wednesday, March 16, 2005 11:16 AM
> > > > postgis-1.0.0-rc3
> > > > On Wed, Mar 16, 2005 at 11:14:26AM -0800, Tomeh, Husam wrote:
> > > > > Under src subdirectory, I see only Makefile.global.in , not
> > > > > Makefile.global.
> > > > This usually means you didn't run ./configure from within
> > > > --strk;
> > > > > And under src directory, there's a "makefile" subdirectory
> > > > > which
> > > > > has
> > > > > Makefile.solaris ; but I can see Makefile.port.
> > > > > Yes I did set up PGSQL_SRC to /p01/postgresql-8.0.1
> > > > >  Husam
> > > > > Behalf
> > > > > Sent: Wednesday, March 16, 2005 9:39 AM
> > > > > postgis-1.0.0-rc3
> > > > > On Wed, Mar 16, 2005 at 09:25:44AM -0800, Tomeh, Husam wrote:
> > > > > > Hello,
> > > > > > According to the sysadmin, the make I used is a GNU make.
> > > > > Weird... do you have the PGSQL_SRC variable set ?
> > > > > Does setting it to base source of postgresql help ?
> > > > > Is your postgresql source tree configured ?
> > > > > --strk;
> > > > > > Thanks,
> > > > > >    PKGINST:  SMCmake
> > > > > >       ARCH:  sparc
> > > > > >    VERSION:  3.80
> > > > > >    BASEDIR:  /usr/local
> > > > > >                    5 shared pathnames
> > > > > >                    7 directories
> > > > > >                    1 executables
> > > > > > Behalf
> > > > > > Sent: Friday, March 11, 2005 10:24 PM
> > > > > > To: postgis-users at postgis.refractions.net
> > > > > > postgis-1.0.0-rc3
> > > > > > On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam
wrote:
> > > > > > > I have installed PostgreSQL 8 on my Solaris 2.8 dev
machine.
> > > > > > > I
> > > > > > > installed
> > > > > > > Proj.4 and GEOS spatial libraries and have been trying to
> > > > > > > install the PostGIS library with no luck so far. I
> > > > > > > downloaded and extracted
> > > > > > > postgis-1.0.0-rc3 under the the contrib subdirectory. When
> > > > > > > I
> > > > > > > run
> > > > > > > "make", I get errors not finding other Making.* files
> > > > > > > under
> > > "src".
> > > > > > > I
> > > > > > > checked for these Making.* files and they do exist!!
> > > > > > > However; I keep
> > > > > > > getting the following errors when I run "make":
> > > > > > You need GNU make, try 'gmake' instead of 'make' and see if
> > > > > > it
> > > > > > fixes
> > > > > > the problem.
> > > > > > --strk;
> > > > > > > :) make
> > > > > > > make -C lwgeom
> > > > > > > ../Makefile.config:90: /src/Makefile.global: No such file
> > > > > > > or
> > > > > > > directory
> > > > > > > Makefile:98: /src/Makefile.shlib: No such file or
> > > > > > > directory
> > > > > > > make[1]: *** No rule to make target `/src/Makefile.shlib'.
> > > Stop.
> > > > > > > Any idea is highly appreciated. Thanks,
> > > > > > >    Husam
> This message contains confidential information intended only for the
> use of the addressee(s) named above and may contain information that
> is legally privileged.  If you are not the addressee, or the person
> responsible for delivering it to the addressee, you are hereby
> notified that reading, disseminating, distributing or copying this
> message is strictly prohibited.  If you have received this message by
> mistake, please immediately notify us by replying to the message and
> delete the original message immediately thereafter.
> Thank you.                                       FADLD Tag
> postgis-users mailing list
