[postgis-users] Installation Error - postgis-1.0.0-rc4
strk at refractions.net
Mon Mar 21 12:35:29 PST 2005
This is weird... maybe your SA have a MAKE variable set in the
environment ? Pointing somewhere else ?
GNU Make 3.80 does support the -C flag.
--strk;
On Mon, Mar 21, 2005 at 12:30:50PM -0800, Tomeh, Husam wrote:
> That's what the SA informed me. Here's the output from : make --version
> anadev10 /p01/download :) make --version
> GNU Make 3.80
> Copyright (C) 2002 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.
> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> Husam
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Monday, March 21, 2005 12:18 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Installation Error - postgis-1.0.0-rc4
> > anadev10#pkginfo -l SMCmake
> Are you sure 'SMCmake' is what you are running ?
> Try
> # make --version
> --strk;
> On Mon, Mar 21, 2005 at 11:51:58AM -0800, Tomeh, Husam wrote:
> > When SA attempt to install it, it complain about "-C" of make.
> > anadev10#pwd
> > /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4
> > anadev10#make install
> > make -C lwgeom
> > Usage : make [ -f makefile ][ -K statefile ]... [ -d ][ -dd ][ -D ][
> > -DD ]
> > [ -e ][ -i ][ -k ][ -n ][ -p ][ -P ][ -q ][ -r ][ -s ][
> > -S ][ -t ]
> > [ -u ][ -w ][ -V ][ target... ][ macro=value... ][ "macro
> > +=value"... ]
> > make: Fatal error: Unknown option `-C'
> > *** Error code 1
> > make: Fatal error: Command failed for target `liblwgeom'
> > ___________________________________________
> > This is the make we have on that server:
> > > > > > > PKGINST: SMCmake
> > > > > > > CATEGORY: application
> > > > > > > ARCH: sparc
> > > > > > > VERSION: 3.80
> > > > > > > BASEDIR: /usr/local
> > > > > > > VENDOR: Free Software Foundation
> > > > > > > PSTAMP: Steve Christensen
> > > > > > > INSTDATE: Mar 15 2005 13:51
> > > > > > > EMAIL: steve at smc.vnet.net
> > > > > > > STATUS: completely installed
> > > > > > > FILES: 50 installed pathnames
> > > > > > > 5 shared pathnames
> > > > > > > 7 directories
> > > > > > > 1 executables
> > > > > > > 4661 blocks used (approx)
> > Husam
> > Tomeh, Husam
> > Sent: Monday, March 21, 2005 11:27 AM
> > Subject: RE: [postgis-users] Compilation Error - postgis-1.0.0-rc4
> > That worked. Thanks for your help. Compiled perfectly.
> > Sent: Monday, March 21, 2005 11:21 AM
> > Subject: Re: [postgis-users] Compilation Error - postgis-1.0.0-rc4
> > On Mon, Mar 21, 2005 at 10:22:03AM -0800, Tomeh, Husam wrote:
> > > Thanks. I created the patch file and placed it on postgis. I ran
> > > "patch < Makefile.patch" and got this error:
> > > Looks like a unified context diff.
> > > I can't seem to find a patch in there anywhere.
> > > Was this the right procedure to install your patch?
> > > Thanks,
> > Do it manually.. it basically quotes grep argument:
> > grep -v ^#
> > becomes:
> > grep -v '^#'
> > --strk;
> > > Husam
> > > Sent: Monday, March 21, 2005 9:30 AM
> > > On Mon, Mar 21, 2005 at 09:23:37AM -0800, Tomeh, Husam wrote:
> > > > Since I'm still having problems with rc3, I downloaded rc4. I get
> > > > the following error when running make:
> > > > cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
> > > > 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.0:g;s:@POSTGIS_VERSIO
> > > > N@
> > > > :1
> > > > .0
> > > > USE_GEOS=1 USE_PROJ=1
> > > > USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.2.1:g;s/@POSTGIS_BUILD
> > > > _D
> > > > AT
> > > > E@
> > > > /2005-03-21 17:13:03/g' | grep -v ^# > lwpostgis.sql
> > > Apply this patch and see what happen:
> > > Index: lwgeom/Makefile
> > > RCS file: /home/cvs/postgis/postgis/lwgeom/Makefile,v
> > > retrieving revision 1.72
> > > diff -U2 -r1.72 Makefile
> > > --- lwgeom/Makefile 18 Mar 2005 12:43:23 -0000 1.72
> > > +++ lwgeom/Makefile 21 Mar 2005 17:46:41 -0000
> > > @@ -139,5 +139,5 @@
> > > lwpostgis.sql: lwpostgis.sql.in
> > > - cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< |
> sed
> > -e
> > > 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POST
> > > GI
> > > S_
> > > VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTG
> > > IS _B UILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v ^# > $@
> > > + cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< |
> > > + sed -e
> > > + 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(PO
> > > + ST
> > > + GI
> > > + S_VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@P
> > > + OS TG IS_BUILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> > > install: all installdirs install-lwgeom-lib install-lwgeom-scripts
> > > --strk;
> > > > cp lwpostgis.sql ..
> > > > Usage: grep -hblcnsviw pattern file . . .
> > > > cp: cannot access lwpostgis.sql
> > > > make[1]: *** [../lwpostgis.sql] Error 2
> > > > make[1]: Leaving directory
> > > > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4/lwgeom'
> > > > make: *** [liblwgeom] Error 2
> > > > Any thoughts?
> > > > Thanks,
> > > > Husam
> > > > Of strk at refractions.net
> > > > Sent: Friday, March 18, 2005 9:18 AM
> > > > Subject: Re: [postgis-users] Unusual Make/Compilation Error -
> > > > postgis-1.0.0-rc3
> > > > On Fri, Mar 18, 2005 at 08:24:05AM -0800, Tomeh, Husam wrote:
> > > > > Although I did run configure before; however, running it again
> > > > > did
> > > > help.
> > > > > I ran into another error (see below). Is setting up postgis on a
> > > > > Linux
> > > > > more straightforward than Solaris? Or it does not matter really?
> > > > Try current CVS, it contains the parser files already so you don't
> > > > have to generate them again.
> > > > --strk;
> > > > > Thanks..
> > > > > anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make
> > > > > make -C lwgeom
> > > > > make[1]: Entering directory
> > > > > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> > > > > sh ../geos_version.sh /usr/local > postgis_geos_version.h bison
> > > > > -y
> > > > > -vd
> > > > > -p lwg_parse_yy wktparse.y
> > > > > make[1]: *** [wktparse.tab.c] Broken Pipe
> > > > > Husam
> > > > > Sent: Wednesday, March 16, 2005 11:16 AM
> > > > > postgis-1.0.0-rc3
> > > > > On Wed, Mar 16, 2005 at 11:14:26AM -0800, Tomeh, Husam wrote:
> > > > > > Under src subdirectory, I see only Makefile.global.in , not
> > > > > > Makefile.global.
> > > > > This usually means you didn't run ./configure from within
> > > > > --strk;
> > > > > > And under src directory, there's a "makefile" subdirectory
> > > > > > which
> > > > > > has
> > > > > > Makefile.solaris ; but I can see Makefile.port.
> > > > > > Yes I did set up PGSQL_SRC to /p01/postgresql-8.0.1
> > > > > > Husam
> > > > > > Behalf
> > > > > > Sent: Wednesday, March 16, 2005 9:39 AM
> > > > > > postgis-1.0.0-rc3
> > > > > > On Wed, Mar 16, 2005 at 09:25:44AM -0800, Tomeh, Husam wrote:
> > > > > > > Hello,
> > > > > > > According to the sysadmin, the make I used is a GNU make.
> > > > > > Weird... do you have the PGSQL_SRC variable set ?
> > > > > > Does setting it to base source of postgresql help ?
> > > > > > Is your postgresql source tree configured ?
> > > > > > --strk;
> > > > > > > Thanks,
> > > > > > > PKGINST: SMCmake
> > > > > > > ARCH: sparc
> > > > > > > VERSION: 3.80
> > > > > > > BASEDIR: /usr/local
> > > > > > > 5 shared pathnames
> > > > > > > 7 directories
> > > > > > > 1 executables
> > > > > > > Behalf
> > > > > > > Sent: Friday, March 11, 2005 10:24 PM
> > > > > > > To: postgis-users at postgis.refractions.net
> > > > > > > postgis-1.0.0-rc3
> > > > > > > On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam
> wrote:
> > > > > > > > I have installed PostgreSQL 8 on my Solaris 2.8 dev
> machine.
> > > > > > > > I
> > > > > > > > installed
> > > > > > > > Proj.4 and GEOS spatial libraries and have been trying to
> > > > > > > > install the PostGIS library with no luck so far. I
> > > > > > > > downloaded and extracted
> > > > > > > > postgis-1.0.0-rc3 under the the contrib subdirectory. When
> > > > > > > > I
> > > > > > > > run
> > > > > > > > "make", I get errors not finding other Making.* files
> > > > > > > > under
> > > > "src".
> > > > > > > > I
> > > > > > > > checked for these Making.* files and they do exist!!
> > > > > > > > However; I keep
> > > > > > > > getting the following errors when I run "make":
> > > > > > > You need GNU make, try 'gmake' instead of 'make' and see if
> > > > > > > it
> > > > > > > fixes
> > > > > > > the problem.
> > > > > > > --strk;
> > > > > > > > :) make
> > > > > > > > make -C lwgeom
> > > > > > > > ../Makefile.config:90: /src/Makefile.global: No such file
> > > > > > > > or
> > > > > > > > directory
> > > > > > > > Makefile:98: /src/Makefile.shlib: No such file or
> > > > > > > > directory
> > > > > > > > make[1]: *** No rule to make target `/src/Makefile.shlib'.
> > > > Stop.
> > > > > > > > Any idea is highly appreciated. Thanks,
> > > > > > > > Husam
> > This message contains confidential information intended only for the
> > use of the addressee(s) named above and may contain information that
> > is legally privileged. If you are not the addressee, or the person
> > responsible for delivering it to the addressee, you are hereby
> > notified that reading, disseminating, distributing or copying this
> > message is strictly prohibited. If you have received this message by
> > mistake, please immediately notify us by replying to the message and
> > delete the original message immediately thereafter.
> > Thank you. FADLD Tag
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
