[postgis-users] pgsql2shp buffer
strk at refractions.net
Fri Mar 25 12:03:31 PST 2005
pgsql2shp calls DBFWriteAttributeDirectly from shapelib at each record,
with no own buffering.
I suggest you try with pgsql2shp from postgis-1.0.0, as it should
work with all postgis versions, and it is actively maintained.
--strk;
On Fri, Mar 25, 2005 at 02:25:47PM -0500, Purvis, Charlton wrote:
> Hi, folks:
> I'm curious if pgsql2shp writes to a buffer of some sort before it actually
> starts writing to a .dbf. I'm trying to dump about 0.5 million rows which
> shouldn't be too bad and shouldn't take too long. However, pgsql2shp seems
> to sit there w/ only a 1 byte (or KB?) .dbf. Should I turn on debugging?
> I'd hate to recompile PostGIS.
> If I type a select * from table_name (the one I'm trying to create the shp
> from), it returns w/i a minute or two. But I'm sure psql is doing buffering
> of its own.
> postgresql-7.4.1/contrib/postgis-0.8.1
> Thanks,
> Charlton
> Charlton Purvis
> (803) 777-8858 : voice
> (803) 777-3935 : fax
> cpurvis at sc.edu
> Baruch Institute
> University of South Carolina
> Columbia, SC 29208
> postgis-users mailing list
