[postgis-users] SQL Crashes Server
strk at refractions.net
Mon Mar 28 09:19:31 PST 2005
Is your wkb_geometry an hexwkb representation ?
Is your postgis installation sane (check output of postgis_full_version) ?
Can you provide a full-encosed test file for us to check ?
--strk;
On Mon, Mar 28, 2005 at 11:14:50AM -0600, Simpson wrote:
> Greetings,
> I have loaded several states of road data from TigerLine 2004 and now
> spatial queries on the table are crashing the server:
> select count(*) from roads WHERE wkb_geometry &&
> setSRID('BOX3D(-89.8236106236772 30.0599242582496,-89.4893166693257
> 30.2718478483578)'::BOX3D, 4269 );
> server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> I ran "vacuum analyze roads", but it didn't help.
> I can run other queries on the table without any trouble.
> I tried to search for not isvalid:
> tiger2004=# select count(*) from roads where not isvalid(wkb_geometry);
> The connection to the server was lost. Attempting reset: Succeeded.
> It seems there is something in the geometry column of one of the rows
> causing spatial functions to crash the server.
> Does anyone have any suggestions on how to determine which row is having
> issues, or any information on how to fix this?
> Thanks for any info,
> Drew.
> ================================= VERSION INFO
> postgis version 1.0.0-rc4 from 3/18/05
> postgresql 8.0
> linux 2.4.18-14 #1 Wed Sep 4 12:13:11 EDT 2002 i686 athlon i386 GNU/Linux
> ================================== TABLE INFO
> tiger2004=# \d roads
> Table "public.roads"
> Column | Type | Modifiers
> ogc_fid | integer | not null default
> nextval('public.roads_ogc_fid_s
> eq'::text)
> module | character(8) |
> tlid | numeric(10,0) |
> side1 | numeric(1,0) |
> source | character(1) |
> fedirp | character(2) |
> fename | character(30) |
> fetype | character(4) |
> fedirs | character(2) |
> cfcc | character(3) |
> fraddl | character(11) |
> toaddl | character(11) |
> fraddr | character(11) |
> toaddr | character(11) |
> friaddl | character(1) |
> toiaddl | character(1) |
> friaddr | character(1) |
> toiaddr | character(1) |
> zipl | numeric(5,0) |
> zipr | numeric(5,0) |
> aianhhfpl | numeric(5,0) |
> aianhhfpr | numeric(5,0) |
> aihhtlil | character(1) |
> aihhtlir | character(1) |
> census1 | character(1) |
> census2 | character(1) |
> statel | numeric(2,0) |
> stater | numeric(2,0) |
> countyl | numeric(3,0) |
> countyr | numeric(3,0) |
> cousubl | numeric(5,0) |
> cousubr | numeric(5,0) |
> submcdl | numeric(5,0) |
> submcdr | numeric(5,0) |
> placel | numeric(5,0) |
> placer | numeric(5,0) |
> tractl | numeric(6,0) |
> tractr | numeric(6,0) |
> blockl | numeric(4,0) |
> blockr | numeric(4,0) |
> wkb_geometry | geometry |
> Indexes:
> "roads_pkey" PRIMARY KEY, btree (ogc_fid)
> "roads_oid_idx" btree (oid)
> Check constraints:
> "enforce_geotype_wkb_geometry" CHECK (geometrytype(wkb_geometry) =
> 'LINESTRI
> NG'::text OR wkb_geometry IS NULL)
> "enforce_dims_wkb_geometry" CHECK (ndims(wkb_geometry) = 2)
> "enforce_srid_wkb_geometry" CHECK (srid(wkb_geometry) = 4269)
> postgis-users mailing list
