[postgis-users] PostGIS porting to Solaris
Don Drake
dondrake at gmail.com
Mon Mar 28 12:58:53 PST 2005
We've developed a product using PostGIS 0.8.2 using Linux. We're
porting it to Solaris and have run into a problem with the DB crashing
on simple spatial queries.
Here's the query that crashes on Solaris (but not on Linux):
select centroid(GeometryFromText('POLYGON((-86.9671883390996
41.2752652196155,-86.9642032882465 41.2752651809174,-86.9612182374049
41.275265064823,-86.9612184425768 41.2730131125765,-86.9612186477253
41.270761159446,-86.9642034934066 41.2707612755221,-86.9671883390996
41.2707613142141,-86.9671883390996 41.2730132673567,-86.9671883390996
41.2752652196155))', 4326));
I'm running Solaris 9, gcc 3.4.2, postgis 0.8.2, Geo 1.0, Proj 4.4.8,
Postgres 7.4.6.
geo=# select postgis_version();
postgis_version
0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
Here's what I see in the logs:
2005-03-28 14:51:40 LOG: 00000: statement: select
5 41.2752651809174,-86.9612182374049 41.275265064823,-86.9612184425768
41.2730131125765,-86.9612186477253 41.270761159446,-86.9642034934066
41.2707612755221,-86.9671883390996 41.2707613142141,-86.9671883390996
41.2730132673567,-86.9671883390996 41.2752652196155))', 4326))
2005-03-28 14:51:40 DEBUG: 00000: PortalRun
2005-03-28 14:51:51 DEBUG: 00000: forked new backend, pid=14327 socket=9
2005-03-28 14:51:51 DEBUG: 00000: reaping dead processes
2005-03-28 14:51:51 DEBUG: 00000: child process (PID 14317) was
terminated by signal 11
2005-03-28 14:51:51 LOG: 00000: server process (PID 14317) was
2005-03-28 14:51:51 LOG: 00000: terminating any other active server processes
2005-03-28 14:51:51 DEBUG: 00000: sending SIGQUIT to process 14327
2005-03-28 14:51:51 DEBUG: 00000: child process (PID 14327) exited
with exit code 0
2005-03-28 14:51:51 LOG: 00000: all server processes terminated; reinitializing
2005-03-28 14:51:51 DEBUG: 00000: shmem_exit(0)
2005-03-28 14:51:51 DEBUG: 00000: invoking IpcMemoryCreate(size=274382848)
2005-03-28 14:51:52 LOG: 00000: database system was interrupted at
2005-03-28 14:51:19 CST
2005-03-28 14:51:52 LOG: 00000: checkpoint record is at 3/44C22378
2005-03-28 14:51:52 LOG: 00000: redo record is at 3/44C22378; undo
record is at 0/0; shutdown TRUE
2005-03-28 14:51:52 LOG: 00000: next transaction ID: 10171; next OID: 43061793
2005-03-28 14:51:52 LOG: 00000: database system was not properly shut
down; automatic recovery in progress
2005-03-28 14:51:52 LOG: 00000: record with zero length at 3/44C223B8
2005-03-28 14:51:52 LOG: 00000: redo is not required
2005-03-28 14:51:54 LOG: 00000: database system is ready
I trussed the postgres server, and here's the output:
14317: brk(0x00340BD8) = 0
14317: brk(0x00342BD8) = 0
14317: brk(0x00344BD8) = 0
14317: stat64("/usr/local/pgsql/lib/libpostgis.so.0.8", 0xFFBFCD70) = 0
14317: time() = 1112043100
14317: write(2, " 2 0 0 5 - 0 3 - 2 8 1".., 20) = 20
14317: write(2, " D E B U G : 0 0 0 0".., 60) = 60
14317: brk(0x00346BD8) = 0
14317: stat64("/usr/local/pgsql/lib/libpostgis.so.0.8", 0xFFBFD260) = 0
14317: Incurred fault #6, FLTBOUNDS %pc = 0xFED4C73C
14317: siginfo: SIGSEGV SEGV_MAPERR addr=0x00000000
14317: Received signal #11, SIGSEGV [default]
-Don
Donald Drake
President
Drake Consulting
http://www.drakeconsult.com/
http://www.MailLaunder.com/
http://www.mobilemeridian.com/
312-560-1574
