[postgis-users] Getting the bounding box of a feature
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 30 13:44:55 PST 2005
Kurt,
Change you query to:
$extent_sql = "SELECT AsText(EXTENT(public.nmranch04.the_geom)) FROM
public.nmranch04 WHERE (public.nmranch04.ranch_name = ".$ranch.")";
An then you will have to parse the text.
-Steve W.
Menke, Kurt wrote:
> Hello,
> I’m developing a client in using PHP 4.3.4, Mapserver 4.4.1, and PostGIS
> 1.0.0 (PostgreSQL 7.4.1).
> I need to programmatically access the bounding box of a selected polygon
> in a PostGIS feature class so that I can use Mapscript to zoom to it.
> I’ve tested the SQL below in PostgreSQL and it returns: BOX3D(560748.25
> 3881950 0,568816.25 3890818.75 0).   However, when I try to dump the
> results into a PHP variable I can’t seem to access the results.  When I
> try to echo the results out to the page I get “Resource ID #68.
> I’m not familiar with the BOX3D format.  Is there any info on BOX3D out
> there? Does this get returned as a string or an array or something
> else?  If there’s a better way to do this I would very much appreciate
> that info as well.
> $extent_sql = "SELECT EXTENT(public.nmranch04.the_geom)FROM
> Thanks
> Kurt
> Kurt A. Menke
> GIS Analyst/Programmer
> _Mailing Address  ___
> Earth Data Analysis Center
> MSC01 1110
> 1 University of New Mexico
> Albuquerque, New Mexico  87131-0001
> _Street Address___
> Bandelier West, Room 123
> Albuquerque, NM 87131
> Phone:  (505) 277-3622 (ext. 239)
> FAX:  (505) 277-3614
> email:  kmenke at edac.unm.edu
> postgis-users mailing list
