[postgis-users] Problem on Instalation on Fedora Core 3
Jean David TECHER davidtecher at yahoo.fr
Mon May 2 08:34:00 PDT 2005
Houla houlala !!!
What happens ???
U need the PostgreSQL Sources in order to building postgis...
Download it, make and install postgresql then copy postgis sources in "postgresql sources"/contrib
Edit the makefile.config and if U have Geos and proj installed..;Type
USE_GEOS = 1
and
USE_PROJ = 1
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
  ----- Original Message -----
  To: postgis-users at postgis.refractions.net
  Sent: Monday, May 02, 2005 2:45 PM
  Subject: [postgis-users] Problem on Instalation on Fedora Core 3
        Hello,
        This is my first one message to the list.
        There is a problem to install the postgis 0.9.0 I would like to know how to solve.
        I unpack postgis (postgis-0.9.0.tar.gz) at  folder usr/local/pgsql/contrib/
        So I changed the line 45 of file "Makefile" from: subdir=contrib/postgis to: subdir=contrib/postgis-0.9.0 and   started the procedure to install the postgis
        [root at localhost postgis-0.9.0]# make
        Makefile:67: ../../src/Makefile.global: Arquivo ou diretório não encontrado
        Makefile:189: /src/Makefile.shlib: Arquivo ou diretório não encontrado
        make: *** Sem regra para processar o alvo `/src/Makefile.shlib'.  Pare.
        Translation of the latest line: make: *** Whitout roule to process target `/src/Makefile.shlib'.  Pare.
        I would like to know what is wrong with it.
        Please tell me what I did wrong.
        Best Regards
        Ezequias Rodrigues da Rocha
                                          Atenciosamente (Sincerely)
                                        * www.recife.pe.gov.br
        A pior das democracias ainda é melhor do que a melhor das ditaduras
        The worst of democracies is still better than the better of dictatorships
          MSN Messenger: ezequias at hotmail.com
  postgis-users mailing list
  http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050502/d605977e/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050502/d605977e/attachment.jpe>
