[postgis-users] [Fwd: [Pkg-grass-general] Uploaded postgis 1.0.0RELEASE-4 (source all i386) to debian-gis]
alex bodnaru alexbodn at 012.net.il
Tue May 10 17:36:49 PDT 2005
hi stephen,
thanks for considering my work.
any comments will be highly welcome, so please take a look at the source
package.
as postgis is been supported for postgresql 7.2 and newer, i have done
my best eforts to make debian usable packages for those versions. thus,
postgis has been tested on stable, testing and unstable debian.
though the package has been uploaded to unstable (under sponsorship of
giuseppe sacco), i will be very glad to hear postgis package could be
built on experimental.
the same postgresql abstraction for postgresql-contrib is said to be now
worked on in postgis upstream, so we don't have to wait for 8.0.
i will happily repackage postgis for later upstream releases, with
postgresql abstraction that will allow for smaller debian source
packages.
best regards,
alex
On Thu, 2005-05-05 at 00:21 -0400, Stephen Frost wrote:
> * alex bodnaru (alexbodn at 012.net.il) wrote:
> > i am forwarding the announcement of a new debian package sub-release.
> > i hope that the next upload will already be in debian unstable.
> I did some work on packaging postgis myself once upon a time.  One
> annoyence I had with it was that it wanted to build inside the Postgres
> source tree.  I fixed this by hacking up the various makefiles and
> whatnot a bit.  Has this issue in PostGIS been fixed upstream, or did
> you do the same?
> Also, have you checked out the PostgreSQL 8.0 packages in experimental?
> It'd be neat to have PostGIS packages which used them, perhaps also
> uploaded to experimental.
> If you need any assistance with the packaging or getting it into
> unstable, let me know.
> 	Thanks,
> 		Stephen
> postgis-users mailing list
