[postgis-users] postgis_restore.pl patch to allow psql options
James Marca
jmarca at translab.its.uci.edu
Tue May 17 14:31:35 PDT 2005
Hi, this is my third and final patch to postgis_restore.pl which
allows one to pass psql options, such as username, host, and port.
It must be applied after the previous "addpod" patch, but I broke it
out so that the maintainers can better decide what to keep and what to
reject.
Finally, note that while I have used the final script on my machine, I
only upgraded from postgres 8.0.1, postgis 1rc3 -> postgres 8.0.1,
postgis 1.0.0, and I only did so on my Linux box.
Hope this is useful.
James
--- postgis-1.0.0/utils/postgis_restore.pl.pod 2005-05-17 14:15:15.000000000 -0700
+++ postgis-1.0.0/utils/postgis_restore.pl 2005-05-17 14:18:52.000000000 -0700
@@ -38,12 +38,34 @@
use strict;
use warnings;
+use Getopt::Long;
use Pod::Usage;
# eval "exec perl -w $0 $@"
# if (0);
-(@ARGV == 3) || pod2usage(-exitstatus => 0, -verbose => 2);
+# (@ARGV == 3) || pod2usage(-exitstatus => 0, -verbose => 2);
+# Grab options from the command line
+my $help = 0;
+my $man = 0;
+my $dbuser = getlogin();
+my $dbhost="";
+my $dbport="";
+my $dbpassword=undef;
+my $p = new Getopt::Long::Parser;
+$p->getoptions
+ ( 'user|username|U=s' => \$dbuser,
+ 'host|h=s' => \$dbhost,
+ 'password|W' => \$dbpassword, #does nothing, but lets people enter something
+ 'port|p=i' => \$dbport,
+ 'help|?' => \$help, # see the pod (--help)
+ 'man|pod' => \$man,
+ ) or pod2usage(2);
+pod2usage(-verbose=>1) if $help;
+pod2usage(-exitval => 0, -verbose => 2) if $man;
my $DEBUG=1;
@@ -104,6 +126,12 @@ my %obsoleted_function = (
my $postgissql = $ARGV[0];
my $dbname = $ARGV[1];
my $dump = $ARGV[2];
+if ( ! $dump ) {
+ pod2usage(-exitval => 2, -verbose => 0,
+ -msg => "Cannot proceed without a dumpfile to process.");
my $dumplist=$dump.".list";
my $dumpascii=$dump.".ascii";
@@ -111,12 +139,29 @@ print "postgis.sql is $postgissql\n";
print "dbname is $dbname\n";
print "dumpfile is $dump\n";
-# form the various client program commands, for use later
+# form the various client program commands, with appropriate options
-my $pg_restore_command= "pg_restore ";
-my $createdb_command = "createdb ";
-my $createlang_command = "createlang ";
-my $psql_command = "psql ";
+my $pg_restore_command= "pg_restore -U $dbuser -W";
+my $createdb_command = "createdb -U $dbuser -W ";
+my $createlang_command = "createlang -U $dbuser -W ";
+my $psql_command = "psql -U $dbuser -W ";
+if($dbhost){
+ foreach ($pg_restore_command,
+ $createdb_command,
+ $createlang_command,
+ $psql_command){
+ $_ .=" -h $dbhost ";
+if($dbport){
+ $psql_command){
+ $_ .=" -p $dbport ";
# Scan postgis.sql
@@ -675,6 +720,16 @@ Arguments:
db --- the new database name. This cannot be an existing database
dump --- the dump file created by pg_dump
+Options:
+ -h, --host=HOSTNAME database server host or socket directory
+ -p, --port=PORT database server port number
+ -U, --username=NAME connect as specified database user
+ -W, --password force password prompt (automatic, included
+ only to mimic psql interface)
+ --help,? brief help message
+ --man, --pod full documentation
=head1 ARGUMENTS
=over
@@ -705,6 +760,50 @@ to get a dump file called olddb.dump
=back
+=head1 OPTIONS
+=over
+=item B<-h, --host>=HOSTNAME
+Specifies the host name of the machine on which the server is running.
+If the value begins with a slash, it is used as the directory for the
+Unix- domain socket. If omitted, the behavior will be identical to
+that of psql without passing the -h option.
+=item B<-p, --port>=port
+Specifies the TCP port or the local Unix-domain socket file extension
+on which the server is lis- tening for connections. Defaults to the
+value of the PGPORT environment variable or, if not set, to the port
+specified at PostgreSQL compile time (usually 5432).
+=item B<-U, --username>=username
+Connect to the database as the user username instead of the default.
+(You must have permission to do so, of course.) If omitted, the
+default current user will be obtained explicitly by a (Perl) call to
+getlogin().
+=item B<-W, --password>
+This option isn't used. In the future, if this script is extended to
+use the Perl DBI, then this option will allow one to pass in the
+correct password for the given username. At the moment, all calls to
+psql, pg_restore, etc explicitly include the '-W' parameter,
+regardless of the contents of this command line option.
+=item B<--help>
+Print a brief help message and exits.
+=item B<--man>, B<--pod>
+Prints this manual page and exits.
+=back
=head1 DESCRIPTION
B<postgis_restore.pl> is aimed at restoring postgis data from a
@@ -761,8 +860,8 @@ The original code was tested on the foll
=back
-Note that this version, which adds pod, pod2usage calls, and modifies
-some small pieces of logic, has not been tested on these platforms.
+This version, which includes host, port, and username options, has not
+been tested on these platforms.
=head1 AUTHOR
