[postgis-users] Buffer Funtion
Nicolas Ribot nicky666 at gmail.com
Wed May 18 05:32:45 PDT 2005
Hi Marcello,
You can do something like:
create table buff_table as select col1, col2, ..., buffer(the_geom,
10) from original_table;
where the_geom is the name of your geographic column in original_table.
You can also create the destination table first, then update its
geometric column with the buffers of your original points.
Nicolas
On 5/16/05, Marcello Benigno B. de Barros Filho
<marcello_benigno at yahoo.com.br> wrote:
> Dear all,
> How to use buffer function? I have one table with points (call pontos) and
> need create another with respective pontos buffer geometry.
> Regards,
> Marcello
> postgis-users mailing list
