[postgis-users] Columnname GEOMETRY
Uwe Dalluege
uwe.dalluege at rzcn.haw-hamburg.de
Fri May 27 06:18:12 PDT 2005
I have a problem with the columnname "GEOMETRY".
When I do this:
create table point ( NR int4 );
select AddGeometryColumn ( 'dbgeo', 'point', 'GEOMETRY', 0, 'POINT', 3 );
insert into point ( nr, GEOMETRY ) values ( 100, GeometryFromText ( 'POINT
( 100.0 200.0 10.3 )', 0 ) );
select * from point;
I receive the errormessage:
ERROR: column "geometry" of relation "point" does not exist
But this works:
select AddGeometryColumn ( 'dbgeo', 'point', 'geometry', 0, 'POINT', 3 );
insert into point ( nr, geometry ) values ( 100, GeometryFromText ( 'POINT
Is there a different between the columnname "GEOMETRY" and "geometry"?
Uwe
