[postgis-users] Columnname GEOMETRY
Abe Gillespie abe.gillespie at gmail.com
Fri May 27 07:48:39 PDT 2005
Are you sure the column name is "GEOMETRY" (uppercase) and not
"geometry" (lowercase)?  You have to take an extra step when creating
a table to make anything uppercase - by default Postgres forces
everything to lowercase.  It's a matter of:
CREATE TABLE foo
  "GEOMETRY" int4
instead of
CREATE TABLE foo
  GEOMETRY int4
-Abe
On 5/27/05, Uwe Dalluege <uwe.dalluege at rzcn.haw-hamburg.de> wrote:
> Hi,
> I have a problem with the columnname "GEOMETRY".
> When I do this:
> create table point ( NR int4 );
> select AddGeometryColumn ( 'dbgeo', 'point', 'GEOMETRY', 0, 'POINT', 3 );
> insert into point ( nr, GEOMETRY ) values ( 100, GeometryFromText ( 'POINT
> ( 100.0 200.0 10.3 )', 0 ) );
> select * from point;
> I receive the errormessage:
> ERROR:  column "geometry" of relation "point" does not exist
> But this works:
> select AddGeometryColumn ( 'dbgeo', 'point', 'geometry', 0, 'POINT', 3 );
> insert into point ( nr, geometry ) values ( 100, GeometryFromText ( 'POINT
> Is there a different between the columnname "GEOMETRY" and "geometry"?
> Uwe
> postgis-users mailing list
