[postgis-users] Postgis install problem under Suse 9.3
Daniel daniel.faivre at camptocamp.com
Tue Oct 4 08:06:25 PDT 2005
Yes, I did.
Postgis sources need to be copied in the contrib/ dir of source tree. as
said in postgis manual.
Yours,
dF
Poizot Emmanuel wrote:
> Hi all,
> I try to install postgis under suse 9.3. I did install postgresql
> source from YAST utility but I'm unable to locate them (I assume it's
> in /usr/include/pgsql where I found postgres header source files).
> So I did copy postgis folder in /usr/include/pgsql and cd into it (as
> asking in the README.postgis file).
> But ./configure --enable-autoconf complain about postgresql sources it
> didn't found.
> Does anybody succed installing postgis under suse 9.3 ?
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051004/35dff4af/attachment.vcf>
