AW: [postgis-users] Postgis install problem under Suse 9.3
Uwe Seher
useher at web.de
Wed Oct 5 01:52:24 PDT 2005
Me too under 9.2(dont know if it is different). I downloaded the
pg-Source-tar and extracted it in /usr/src/packages/SOURCES. then i did
./configure and make. I extracted postgis in thge /contrib-folder in the
source tree and compiled it. The only thing that was different to the manual
was to change the variable $libdir in the sql-file with the full path to the
lib.
CU Uwe
-----Ursprüngliche Nachricht-----
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von
Daniel
Gesendet: Dienstag, 4. Oktober 2005 17:06
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] Postgis install problem under Suse 9.3
Yes, I did.
Postgis sources need to be copied in the contrib/ dir of source tree. as
said in postgis manual.
Yours,
dF
Poizot Emmanuel wrote:
> Hi all,
> I try to install postgis under suse 9.3. I did install postgresql
> source from YAST utility but I'm unable to locate them (I assume it's
> in /usr/include/pgsql where I found postgres header source files).
> So I did copy postgis folder in /usr/include/pgsql and cd into it (as
> asking in the README.postgis file).
> But ./configure --enable-autoconf complain about postgresql sources it
> didn't found.
> Does anybody succed installing postgis under suse 9.3 ?
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
____________
Virus checked by G DATA AntiVirusKit
Version: AVK 16.802 from 04.10.2005
Virus news: www.antiviruslab.com
