[postgis-users] Install PostGIS from a server script?
david techer
davidtecher at yahoo.fr
Mon Oct 10 16:34:06 PDT 2005
Hi
This should not be the better solution...but I think U should try using a Template from postgresql
On Server:
Try to make a template called 'mytemplate'
createdb mytemplate
createlang plpgsql mytemplate
psql -d mytemplate -f /path/to/lwpostgis.sql
psql -d mytemplate -f /path/to/spatial_ref_sys.sql
But don't do this on template0 or template1! template0 is needed by PostgreSQL.
If U do this on template1 U should have to reinitialize template1 later using initdb if
U do something like upgrading.
Then on Client (Windows):
in order to create a DataBase called 'mydb' with postgis function:
createdb -T mytemplate mydb
Actually there is few commands for mytemplate being "frozen" but I don't remember this...
Perhaps should U see postgresql doc.
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Charlie Savage a écrit :Is it possible for a postgresql server to run a script stored on the
server, and not on a client?
>More specifically, I have a Linux server (running postgresql 8.1 beta2
>and the CVS HEAD of postgis) and a Windows client.
>From the windows client I would like to be able to create a database,
>install POSTGIS, and then create various tables/objects and load data.
>I run into problems when trying to install postgis from the windows
>client because obviously "psql -d [yourdatabase] -f lwpostgis.sql"
>doesn't work because lwpostgis.sql is on the server (and even if it was
>one the client it specifies $libdir/liblwgeom.dll instead of
>$libdir/liblwgeom.so).
>Is it possible to do this, or is it disallowed for security reasons?
>Charlie
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
