[postgis-users] shp2pgsql 8.0.4 problems
strk at refractions.net
Sat Oct 29 04:29:17 PDT 2005
I think we can change this back.
It was a bug in previous versions allowing this,
I think we can make it into a feature.
--strk;
On Fri, Oct 28, 2005 at 10:16:51AM -0400, Stephen Woodbridge wrote:
> Hi all,
> We upgraded to 8.0.4 and are having a problem loading some files that we
> loaded in the past without a problem.
> /usr/local/pgsql/bin/shp2pgsql MtdRef mtdref
> Shapefile contains 2446 NULL object(s)
> Basically this file is really just a DBF table of metadata and each row
> has a null shape associated with it. These files loaded on previous
> versions but now generate this error.
> Did something change on 8.0.4 in this regards?
> How do I load a file like this is this is not the best way?
> Is there an option to load just the DBF file that I missed?
> Thanks,
> -Steve W.
> postgis-users mailing list
