[postgis-users] postgis & php
Nelson Guda
nelsong at mail.utexas.edu
Mon Apr 3 12:52:53 PDT 2006
Hi all,
I am relatively new to postgis. I've got a database up and running,
and have used much of the language already. I am looking for a php
protocol that can run shp2pgsql and pgsql2shp so that i can use these
functions via a web interface.
Unfortunately my understanding of programming languages is very
limited - mostly I have used postgis through pgadmin.
I found a set of php classes on the web that include a function for
shp2pgsql, but I cannot seem to get it working. I'll copy those
functions below. I don't understand what I might need to change to
make this work. Can anyone help me out with this?
Thanks much,
nelsong
-- -- -- -- -- -- -- Postgis classes -- -- -- -- -- -- --
* @author Paul Scott
* @copyright Paul Scott
* GPL Package
* Please include credit to me is you use this class!
function connect()
$dbname = 'cdsm';
$port = '5432';
$host = 'localhost';
$dbconn = pg_connect("host=$host port=$port dbname=$dbname");
if($dbconn)
return true;
else
return false;
function close()
$shutdown = pg_close($dbconn);
if($shutdown)
return true;
else
return false;
//function to insert shapefiles (ESRI) into PostGIS DB
function create_sql($filename,$dbname)
//create the tablename from the filename (replace the .shp with shp)
$tablename1 = str_replace('.','',$filename);
//Remove last three chars from table name ('shp' is discarded)
$tablename = substr($tablename1,0,-3);
//Give the log file a name by tacking .log onto the table name
$logfile = $tablename.".log";
//execute the shell script that does all the real work (thanks
refractions.net)
$ret = shell_exec("/usr/local/pgsql/bin/shp2pgsql $filename
$tablename|/usr/local/pgsql/bin/psql -d $dbname 2>&1");
echo $ret; //debug only (displays the results)
//open a file handle for binary safe write - this creates a
logfile...Use it or leave it, just an extra
$handle = fopen($logfile,'w');
//Write the log data to a file
fwrite($handle, $ret);
//close the file handle
fclose($handle);
function shp2pgsql($filename,$dbname)
//loop through all the shapefiles and perform the function on them
foreach (glob("*.shp") as $filename)
//display the file size and name that we are currently working on
//echo "$filename size " . filesize($filename) . "<br><br>\n";
//do the sql-ize and insert the data, also write a log
create_sql($filename,$dbname);
}//end foreach
}//end function
