[postgis-users] Data from function inside mapserver
Paul Ramsey
pramsey at refractions.net
Sat Apr 15 11:36:29 PDT 2006
This is the correct form below.
On 15-Apr-06, at 11:30 AM, Josh Livni wrote:
> PS I also tried [DATA "the_geom from (select * from
> get_symbolized...) as foo using srid=5555"] to no avail
Does "select * from get_symbolized(...)" in psql return a result set
(like a select on a table or view)? If so, is one of the columns
named "the_geom"? If so, then I am running out of ideas, left only
with replacing the "*" in your select query with a properly itemized
list of column names.
