[postgis-users] PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
alex bodnaru alexbodn at 012.net.il
Mon Apr 17 05:15:37 PDT 2006
hi,
i don't have ubuntu, but the available debian packages have been
designed to support even older postgresql architectures.
the dependencies have been based on packages names, and the real file
names are been detected at build-time.
my suggestion would be to try to build the deb from it's sources on each
ubuntu or debian distribution to support.
willing to help,
alex
Stefano Costa wrote:
> Scrive Paul Scott <pscott at uwc.ac.za>:
>>On Mon, 2006-04-17 at 13:23 +0300, alex bodnaru wrote:
>>>hi paul,
>>>you may even install genuine debian packages from debian gis.
>>I tried to, but the debian packages depended on libgcc-base greater than
>>what Breezy comes with. The first attempt would have broken my system
>>completely, thus the reason for the wiki page... It also calls for
>>libgeos2c2a which is uninstallabe.
> Maybe the DebGIS work on Dapper, not sure, still on Breezy here.. ;)
> The integration between DebGIS and Ubuntu is usually a problem at this moment.
> Some effort is required to get a UbuntuGIS repository up and working. Check out
> http://wiki.ubuntu.com/UbuntuGIS for a (confused) patchwork of ideas and links
> about that.
> Regards, Steko
> Stefano Costa
> http://www.iosa.it * Software Libero per l'Archeologia
> Jabber: steko at jabber.linux.it
> This message was sent using IMP, the Internet Messaging Program.
> postgis-users mailing list
