[postgis-users] Calculate the distance
Tyler Mitchell
tylermitchell at shaw.ca
Sat Aug 5 16:56:58 PDT 2006
Hi Gates,
The unit returned will be the distance in the same units as the
source data in the_geom column.
Tyler
On 5-Aug-06, at 4:47 PM, gates jr wrote:
> I’m Gates, a university student. I got two problems:
> I have a table called “state_point table”. I calculate the distance
> between a new point to all point in my table with query:
> CREATE TABLE distance AS
> SELECT distance(state_point.the_geom, geomfromtext('POINT(100000
> 200000)',-1)) AS distance, state_id, state_name
> FROM state_point
> order by distance
> My Question is : what measure unit that’s return by this query?
> Meters? Miles? Or another? If it’s not in meters how could I
> convert it to meters?
> I want to make user interface in VB.NET 2005, which driver or
> connection should I use to show my map? Is there any VB.net or
> another language samples, which use postgreSQL/postgis database,
> that I can access in the internet? (a link site? ) I’m a kind of
> people that learn by example.
> Thank
> Gates
> See the all-new, redesigned Yahoo.com. Check it out.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060805/f31409ea/attachment.html>
