[postgis-users] Postgis Java Geometry classes/Hibernate, borken query
Jan Syryn jan.syryn at trasys.be
Fri Dec 1 02:26:49 PST 2006
By setting the property
<!-- Echo all executed SQL to stdout -->
<property name="show_sql">true</property>
in the Hibernate config xml, you'll see all the sql calls sent by Hibernate
in the console.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dave
Potts
Sent: vendredi 1 décembre 2006 11:24
To: PostGIS Users Discussion
Subject: [postgis-users] Postgis Java Geometry classes/Hibernate,borken
query
Hi Folks
I am using hibernate to query a postgis database.
The majority of my distance queries work as expected, one does not!
For one distance setting I get loads of answers, for a greater distance, I
get none, when I would expect to get at least the first set.
So I suspect that either Hibernate or Postgis are having problems.
I can type the query in by hand and it works as expected , so I don't
suspect the database or postgis interface to the database.
Is there any debug code in postgres/postgi/Hibernate that will actual allow
me work out what data is being sent from postgres to hibernate, what
hibernate is caching and what its forwarding to the end user.
regards
David
