[postgis-users] Compatibility with PostgreSQL 8.1.2
Frank Koormann
frank.koormann at intevation.de
Wed Feb 1 05:11:11 PST 2006
* Bert Hinrichs <a.hinrichs1 at comcast.net> [060201 03:50]:
> >To improve the packages it would be helpful to know where the packages
> >are from and what problems you actually encountered.
> The PostgreSQL packages came from:
> http://www.postgresql.org/ftp/binary/v8.1.2/linux/rpms/fedora/fedora-core-4/
> these packages have names like:
> postgresql-8.1.2-1PGDG.i686.rpm rather than having the typical fc4 kind of
> label I see on the rpms for the 8.0.6 versions currently at fedora/redhat
> sites.
> The PostGis packages came from:
> http://postgis.refractions.net/rpms/fedora/fedora-core-4/
> The problem was a Failed Dependency on PostgreSQL 8.1.1. PostgreSQL 8.1.2
> is installed.
OK, so this seems somewhat out of sync.
> >No. Since PostGIS 1.1.0 you only need the PostgreSQL development
> >packages and can run configure with the
> >--with-pgsql=<FULL PATH to pg_config>
> Ok, but I assume that it would still take the srpm versions of the
> PostgreSQL development packages rather than the binary rpm versions of the
No. I just tested with SuSE (but expect Fedora to be similar on this):
Install the postgresql -devel and -libs packages and go ahead
building your PostGIS.
> and it would still require a build of the source code
> of PostGis and a manual install taking the management of PostGIS out from
> under the typical yum tool. Correct?
You could either build manually from tarball or build a personal rpm
from the srpm.
> Does the PostGIS build environment
> have an uninstall capability in case it needed to be removed?
Yes, you could issue a "make uninstall". This can however leave your
current database with something missing (the postgis libs namely).
HTH,
Frank
Frank Koormann <frank.koormann at intevation.de>
Professional Service around Free Software (http://intevation.net/)
FreeGIS Project (http://freegis.org/)
