[postgis-users] changing a non spatial table to a spatial talble
Kevin Neufeld
kneufeld at refractions.net
Sat Feb 4 23:16:38 PST 2006
> Kirk R. Wythers wrote:
> > 3. ok... 3 questions, what does the 2 at the end of the select statement
> > refer to? Is that x and y?
> The 2 means dimension = 2, ie X,Y. This is all documented in the postGIS
> reference manual which can be found on the postGIS site.
Hmmmmm, according to the PostGIS documentation, "dimension" has nothing to
do with 2D, 3D, or 4D. Rather the dimension is the type of geometry, i.e. 0
for point, 1 for linear, 2 for polygonal.
http://postgis.refractions.net/docs/ch06.html#id2790699
And yet, the "Avoiding dimension conversion" section,
(http://postgis.refractions.net/docs/ch05.html#id2789845) talks about
dimension(...) in the context of 2D, 3D or 4D.
So which is it?
Cheers,
Kevin
