[postgis-users] PostGIS ver. 1.0+ to be supported in ESRI ArcGIS 9.2
J. Tomasz Giermakowski tomas at unm.edu
Wed Feb 15 08:07:33 PST 2006
For those of us trying to integrate PostGIS into ESRI software, it looks
like support will be there in ArcGIS 9.2. For details, see the message i
got regarding the Data Interoperability extension:
Tom,
I spoke to the Data Interoperability extension product specialist regarding
your incident and they were in contact with Safe Software. Safe Software did
not provide support for PostGIS 1.x for FME 2006, but it is to be included with
ESRI Data Interop 9.2.
Data Interop 9.1 was based on FME 2004 ICE^3, which also supported up to
PostGIS 0.9.x.
Please let me know if you have additional questions related to this issue. I am
closing incident #480388 pending further contact from you.
Regards,
Denise K.
To contact ESRI Technical Support (USA only):
Tel: (888)377-4575   Fax: (909)792-0960   E-mail: support at esri.com
For additional support use our 24 Hour Support Services:
   ESRI's WWW homepage         http://www.esri.com
   Online Support Center       http://support.esri.com
   Knowledge Base              http://support.esri.com/search/
   Discussion Forums           http://support.esri.com/forums/
   Scripts & Tools             http://arcscripts.esri.com/
   E-mail Discussion Lists     http://support.esri.com/listserve/
   ESRI Developer Network      http://edn.esri.com/
