[postgis-users] could not load library "/usr/local/pgsql/lib/plpgsql.so"
Markus Schaber schabi at logix-tt.com
Wed Feb 15 06:49:59 PST 2006
Hi, Stefan,
Stefan Schwarzer wrote:
> I try to import a shapefile using the shp2pgsql function. But it  gives
> me an error message, and I have no idea what it tries to tell  me... ;-)
> ERROR:  could not load library "/usr/local/pgsql/lib/plpgsql.so":
> Symbol not found: _resolve_polymorphic_argtypes
>   Referenced from: /usr/local/pgsql/lib/plpgsql.so
>   Expected in: /usr/local/pgsql/bin/postmaster
It seems that yor plpgsql procedural language is not installed correctly.
Can you connect to the database with psql, and issue the following commands:
create function test(text) returns text as 'begin return
''test''||$1;end' language 'plpgsql';
select test(42);
drop function test(text);
They should work without error. If they give the same error as above,
your plpgsql procedural language is broken.
Did you compile/install your postgresql yourself? Do you have a
plpgsql.so anywhere on your systen (try 'locate plpgsql.so' from your
shell).
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in EU! www.ffii.org www.nosoftwarepatents.org
