[postgis-users] intersection direction
David Bitner osgis.lists at gmail.com
Thu Feb 16 12:51:13 PST 2006
Is there a way to get at directionality in an intersection result?
Internally, intersection must be finding the from/to pair of each line
segment that are crossing before it interpolates, if I could calculate
the azimuth of each of those pairs, I could compare those and then
(assuming from/to equates to left/right) determine if the intersecting
line came from above or below.  Any other ideas of how to get at this
information?
Basically, I have a line that I need to test other lines against and
if they come through from one side I don't care, but from the other
side I need to know about it.
